sixpackrt 0 #1 Posted June 15, 2009 1974 wheelhorse lawn tractor Link Share this post Link to post Share on other sites
TJ 184 #2 Posted June 15, 2009 Good price. :thumbs2: Share this post Link to post Share on other sites
sixpackrt 0 #3 Posted June 21, 2009 I picked up the tractor today Share this post Link to post Share on other sites
Sparky-(Admin) 24,026 #4 Posted June 21, 2009 That one was definatly neglected. Glad to see a WH guy has it now and not a scrapyard. So what are your plans for it. A parts machine? A restore? Mike......... Share this post Link to post Share on other sites
sixpackrt 0 #5 Posted June 21, 2009 That one was definatly neglected. Glad to see a WH guy has it now and not a scrapyard. So what are your plans for it. A parts machine? A restore? Mike......... I'm going to restore it. its complete I took the parts off the engine I was just to lazy to pull the flywheel off. I wanted to check the points no spark. From what i seen it was sitting under a tree. had mouse nests in it The guy bought it new. Share this post Link to post Share on other sites
Kelly 1,035 #6 Posted June 21, 2009 You know the points are not under the flywheel right?? they are in the little metal box in the front of the engine as sitting in the tractor. and if you know this I'm sorry. Share this post Link to post Share on other sites
sixpackrt 0 #7 Posted June 21, 2009 You know the points are not under the flywheel right?? they are in the little metal box in the front of the engine as sitting in the tractor. and if you know this I'm sorry. nope didn't know that :thumbs2: Share this post Link to post Share on other sites
sixpackrt 0 #8 Posted June 22, 2009 It's alive had it started on starting fluid today. Cleaned the points fired right up. Carb is soaking right now it was all gummed up. fuel pump is also gummed up. it now has gas with sea foam in it. Share this post Link to post Share on other sites
