Wheelhorse#1 1,901 #1 Posted August 29, 2021 (edited) Not dialed in yet but think this sound a like a rod knocking? What do you think . https://youtube.com/shorts/p54QuxUmfaE?feature=share Edited August 29, 2021 by Wheelhorse#1 Share this post Link to post Share on other sites
squonk 45,534 #2 Posted August 29, 2021 Rod or the balance gears are ready to exit the confines of the block. DO NOT RUN ANYMORE! 3 Share this post Link to post Share on other sites
Wheelhorse#1 1,901 #3 Posted August 29, 2021 Thanks Share this post Link to post Share on other sites
953 nut 64,127 #4 Posted August 29, 2021 7 hours ago, squonk said: DO NOT RUN ANYMORE! The few hours it will take you to unbolt the block from the oil pan will probably save you a bunch of money and heartache. 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,901 #5 Posted August 30, 2021 Thanks for the advice. I’ll be starting on it the next couple days. Share this post Link to post Share on other sites
Wheelhorse#1 1,901 #6 Posted September 2, 2021 (edited) Well I pulled the crank and piston out.I haven’t measured anything yet waiting on a couple things. doesn’t look to bad I guess won’t know for sure till I measure the bore and crank.The other side of the piston looks the same. what do you think ? Edited September 2, 2021 by Wheelhorse#1 Share this post Link to post Share on other sites
Wheelhorse#1 1,901 #7 Posted September 2, 2021 (edited) https://youtube.com/shorts/s5C5FMq6Euk?feature=share Edited September 2, 2021 by Wheelhorse#1 Share this post Link to post Share on other sites
Tuneup 1,452 #8 Posted September 4, 2021 So, was the rod to pin gap too large? Excess crank play? Wondering still on the source of the knock. That piston looks like the engine starved for oil at one time. Not sure about the bore or rings. Almost looks like it's a bore job... 1 Share this post Link to post Share on other sites
squonk 45,534 #9 Posted September 4, 2021 I want to see the bearing surface of the rod. Looks like it was just starting to wipe itself on the crank. That piston scoring is bad. That lower part of the cylinder will destroy a new piston in short order without boring. 1 Share this post Link to post Share on other sites
pacer 3,179 #10 Posted September 4, 2021 That piston and crank look .... ?? I've seen that several times when the engine overheated - low or dirty oil, excess chaff build up in fins, missing fins?, etc. Whatever, some close measurements need to be done ... definitely do not run it with out finding out. Share this post Link to post Share on other sites
953 nut 64,127 #11 Posted September 4, 2021 On 9/2/2021 at 5:01 PM, Wheelhorse#1 said: won’t know for sure till I measure the bore and crank. Don't think I would use that piston for anything but a paperweight. 1 Share this post Link to post Share on other sites
