earlleecliffton 38 #26 Posted August 26, 2021 I got one too 1 1 Share this post Link to post Share on other sites
AHS 1,695 #27 Posted August 27, 2021 Ok, what are 8 pinions vs the other (4 pinion?) I haven’t broken an 8 speed, but the time is young yet!! Share this post Link to post Share on other sites
ebinmaine 79,685 #28 Posted August 27, 2021 1 minute ago, AHS said: Ok, what are 8 pinions vs the other (4 pinion?) I haven’t broken an 8 speed, but the time is young yet!! Pinions are the small gears inside the differential which is surrounded by what's known as The Bull gear. The main drive gear. Horse transmissions have either 4, 8, or 10, pinion gears. Eight pinion transmissions are known to be the strongest because you have larger gears than the 10 pinion transmissions and obviously more of them than the four pinion transmissions so it gives you twice the contact surface to transfer power. 1 Share this post Link to post Share on other sites
AHS 1,695 #29 Posted August 27, 2021 3 hours ago, ebinmaine said: Pinions are the small gears inside the differential which is surrounded by what's known as The Bull gear. The main drive gear. Horse transmissions have either 4, 8, or 10, pinion gears. Eight pinion transmissions are known to be the strongest because you have larger gears than the 10 pinion transmissions and obviously more of them than the four pinion transmissions so it gives you twice the contact surface to transfer power. So, that’s in my 414-8? All 400 series? Share this post Link to post Share on other sites
ebinmaine 79,685 #30 Posted August 27, 2021 11 minutes ago, AHS said: So, that’s in my 414-8? All 400 series? Should be. Yes sir. 1 Share this post Link to post Share on other sites
Sailman 1,307 #31 Posted August 28, 2021 Additional reason for searching for the 416 was the 8 inch front tires instead of the 6 inch. Bigger is better right?? 1 Share this post Link to post Share on other sites
