bell 11 #51 Posted August 3, 2009 Looking GREAT Brian! :thumbs2: Share this post Link to post Share on other sites
TJ 184 #52 Posted August 3, 2009 Thanks for posting your progress. Great job. :thumbs2: Share this post Link to post Share on other sites
buckrancher 2,697 #53 Posted August 5, 2009 Got the starter generator sand blasted and tore apart .The bearing was bad on the pulley end So I cleaned out the carbon dust and checked all the contections and brushes also cleaned the commutator with a scotch-brite pad replaced both bearings and painted Share this post Link to post Share on other sites
nylyon-(Admin) 9,066 #54 Posted August 5, 2009 Very nice and complete job you're doing. I love write-up's like these, they're so great to read. Share this post Link to post Share on other sites
Stigian 1,235 #55 Posted August 8, 2009 WOW... your doing a fantastic job there Brian :thumbs2: Share this post Link to post Share on other sites
buckrancher 2,697 #56 Posted August 9, 2009 Thank you all for your kind comments I'am hoping all the motor parts arrive soon looking forward to hearing her run Share this post Link to post Share on other sites
sodbuster 1 #57 Posted August 13, 2009 the hardest thing about painting,is just do it!! the body work is the hard part!! painting candy,or multi stage is a little more complicated.if this is your first go? it looks good!! Share this post Link to post Share on other sites
buckrancher 2,697 #58 Posted August 19, 2009 I got my new 3" ball flex hone the other day so I honed the cylinder still have not recieved all the motor parts yet new clutch brake rod and front axle pivot pin out of stainless Share this post Link to post Share on other sites
piecrazy4 0 #59 Posted August 23, 2009 Great job on the restore ! Share this post Link to post Share on other sites
perry 82 #60 Posted August 23, 2009 now thats a complete rebuild :thumbs2: Share this post Link to post Share on other sites
sorekiwi 761 #61 Posted August 24, 2009 Really nice job, Brian. One question about the stainless pivot pin... I've pulled about 6 front axles out of Wheelhorse tractors, and on all but one, the pin has been badly worn, but the bore in the axle has been ok. I figure that the soft mild steel pin is kind of sacrificial to save the bore in the axle. Do you think the stainless might be a little hard? :thumbs: Share this post Link to post Share on other sites
buckrancher 2,697 #62 Posted August 24, 2009 Really nice job, Brian. One question about the stainless pivot pin... I've pulled about 6 front axles out of Wheelhorse tractors, and on all but one, the pin has been badly worn, but the bore in the axle has been ok. I figure that the soft mild steel pin is kind of sacrificial to save the bore in the axle. Do you think the stainless might be a little hard? Yes it might be but as this tractor going to be a trailer queen it should not be a problem as long as it's greased well If I was going to use this tractor I would install bronze bushing's in the axle pivot point with the stainless pin :ychain: Share this post Link to post Share on other sites
buckrancher 2,697 #63 Posted August 26, 2009 Motor parts came in saturday so I started reassembly this week lapping in the new valve's. Both seats were in great shape and didn't need cutting Both valve's lapped checking piston ring end clearance governor, camshaft , lifter tappit's new crank bearing's ,crankshaft and side plate installed. Crankshaft was adjusted for side clearance with gasket and one shim ready to install new piston and rod Piston and rod in needs end cap installed and torqued grinding valve stem for end clearance Installing valve's Engine ready to prep for paint All Primed :thumbs2: Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #64 Posted August 26, 2009 Excellent work, Brian. You did remember to lube the heck out of the cam pin, didn't you? (I'm just reminiscing about a guy I know who assembled the cam dry in a big block K and about 45 seconds into the first run the cam seized on the pin, stuff broke, and lots of pieces ended up in the oil pan. ) Although not quite as elaborate as your overhaul, I had a post going over a year ago when my son & I were "freshening up" a K-161. Funny thing is - it's still sitting on the workbench and it's still not finished. LINK to my old post. Share this post Link to post Share on other sites
buckrancher 2,697 #65 Posted August 27, 2009 Excellent work, Brian. You did remember to lube the heck out of the cam pin, didn't you? (I'm just reminiscing about a guy I know who assembled the cam dry in a big block K and about 45 seconds into the first run the cam seized on the pin, stuff broke, and lots of pieces ended up in the oil pan. ) Although not quite as elaborate as your overhaul, I had a post going over a year ago when my son & I were "freshening up" a K-161. Funny thing is - it's still sitting on the workbench and it's still not finished. LINK to my old post. Hey TT yes I did I filled a new glue syringe with 10-30 and injected it in the oil holes on the cam until it came out the ends :ychain: Share this post Link to post Share on other sites
Suburban 550 28 #66 Posted August 27, 2009 Awesome job, Brian. A picture perfect restoration. :thumbs2: Share this post Link to post Share on other sites
buckrancher 2,697 #67 Posted August 31, 2009 Since I'am going to use a stainless steel steering shaft and tie rods I thought a stainless lower steering shaft would be cool too :scratchead: Share this post Link to post Share on other sites
HorseFixer 2,015 #68 Posted September 3, 2009 Looks Great Brian! :scratchead: Share this post Link to post Share on other sites
MikesRJ 563 #69 Posted September 3, 2009 SWEET! :scratchead: Share this post Link to post Share on other sites
mnWHfan 47 #70 Posted September 4, 2009 Brian, You're doing a fantastic job. I just finished doing a C161 Automatic last year that I took to a similar level. I worked on it after hours at work and even drew about 80% of it into my 3D CAD system. It's fun to use the tools that you have access to. Dennis :scratchead: Share this post Link to post Share on other sites
bitten 134 #71 Posted September 4, 2009 Brian Looks as though you arent messing around on this rebuild. cant wait to see the finished prodect. Share this post Link to post Share on other sites
buckrancher 2,697 #72 Posted September 16, 2009 Finally got the engine painted and reassembled all I'm lacking is the decal for the air cleaner which is on back order I fabricated some new parts out of stainless throttle rod, fuel line , generator bracket , dipstick :scratchead: Share this post Link to post Share on other sites
Suburban 550 28 #73 Posted September 16, 2009 Can't wait to see it all finished. Wish I could have spent more time talking horses at the NAMA show on Saturday but I had somewhere I had to be. Maybe next time. :scratchead: Share this post Link to post Share on other sites
mnWHfan 47 #74 Posted September 17, 2009 Brian, That is a good looking engine. Dennis :scratchead: Share this post Link to post Share on other sites
bell 11 #75 Posted September 17, 2009 WOW!!!! LOVE the attention to detail! :scratchead: Share this post Link to post Share on other sites
