Wheelhorse#1 1,890 #1 Posted August 16, 2021 (edited) Hello Folks Anyone know anything about the 3 speed peerless trans? I have a issue that when I apply the break/ clutch where there is a laps of time a few seconds before it will stop and stops hard.I have replace the break lining and adjusted the tension but no difference. so I’m guessing it’s something inside the trans ? It goes into gear just fine all three speeds . thanks for any suggestions there is little info on these trans in the mechanics handbook on these. Edited August 16, 2021 by Wheelhorse#1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,932 #2 Posted August 16, 2021 Models that use a single pedal for clutch and brake require the brake to be adjusted first. Are you sure the belt guard is installed correctly? It does not sound like you have a transmission problem. Poor quality scan of the manual that describes the procedure. Garry 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,890 #3 Posted August 16, 2021 7 hours ago, gwest_ca said: Models that use a single pedal for clutch and brake require the brake to be adjusted first. Are you sure the belt guard is installed correctly? Garry Gary Pretty sure I do but I will double check and check & the break tension.Maybe it loosened some how. thanks for the info Share this post Link to post Share on other sites
