Gregor 4,848 #1 Posted August 14, 2021 I have a Massey Ferguson 16 with a start of a 3 point hitch. Are 3 point hitch parts specific to tractor brands, or are they pretty much generic for most garden tractors? 2 Share this post Link to post Share on other sites
953 nut 66,837 #2 Posted August 15, 2021 You should be able to hang that off the back of a and then get the lower arms from most any small tractor. 1 Share this post Link to post Share on other sites
pacer 3,180 #3 Posted August 15, 2021 VERY doubtful they are same across brands --- for example, even in the same brand. I have a MF1655 and the 3pt is totally different from yours (though the 1650 is the same as the 55) Youre missing a good bit of yours and I bet it'd be a a shocker if you could find them --- Massey parts are more scarce than the horses! My 54" deck is sitting useless because of a pulley I need -- they just are not to be had. (Its cog belt driven and the pulley is PLASTIC!!!, no wonder they dont last!!) But, doggone if my 1655 isnt just a really nice tractor! Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,864 #4 Posted August 15, 2021 3 point hitches are controlled by an ISO specs, i.e. the dimensions between the lower lift arms, the hole diameters, etc., and are listed in categories, category 0 (most garden tractors), category 1 (sub compacts and compacts, etc), category 2, category 3, etc. How a manufacturer makes the 3 point and how to attach it to the tractor is where the differences lie. Below is a couple of the ISOs that controlled the specifications for certain categories of 3 point hitches. There is also a ISO for a sleeve type hitch also. I included it also. BTW, ISO stands for International Standard Organization. ISO_730_3_PT_Hitch.pdf ISO_Three_Point_Hitch.pdf ISO_One_Point_Tubular_Sleeve_Hitch.pdf 1 Share this post Link to post Share on other sites
Handy Don 16,776 #5 Posted August 15, 2021 6 hours ago, T-Mo said: ISO for a sleeve type hitch Well that's my "new thing learned" for today! Thank you. Share this post Link to post Share on other sites
Herder 2,356 #6 Posted August 15, 2021 Massy Ferguson 16. Can we get some pics? Share this post Link to post Share on other sites
Gregor 4,848 #7 Posted August 15, 2021 1975 (?) MF 16. Probably the most complete older tractor I have bought. Everything is there, save the rest of the 3 point hitch. I replaced the coil and condenser, cleaned the points, thoroughly cleaned the fuel system with new lines, and filer, mounted the solenoid to the frame, and put on a China carb. It fired right up. I have 2 14's and have been looking for a 16 for several years. This one popped up on FB, and I was able to snag it up. It needs a little spit and polish, but I will get to it eventually. Now I just need to find my Senior, or lever steer. 1 Share this post Link to post Share on other sites
