dsholler 54 #1 Posted August 5, 2021 I am sure this answer is in here someplace, but all my best searching has not been able to find the right manual or parts diagram. I need to replace the idler pulley in the attachamatic, as it is squealing something awful. The mower belts probably could use an upgrade as well (Its the 48 inch side discharge deck, with the two belts) Does anyone know where to source this pulley? It is the flat one, not the v one. Dan Share this post Link to post Share on other sites
squonk 43,842 #2 Posted August 5, 2021 https://www.wheelhorseforum.com/forum/141-wheelhorse-parts-and-more/ 1 Share this post Link to post Share on other sites
oliver2-44 10,730 #3 Posted August 5, 2021 When you disassemble your mule drive mark the 2 spacers that go through between the pulleys. They are 2 slightly different lengths and need to be reinstalled in the correct places. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,487 #4 Posted August 5, 2021 Share this post Link to post Share on other sites
dsholler 54 #5 Posted August 6, 2021 Thanks for the tip about the spacers. Share this post Link to post Share on other sites
