Paul Dietrich 19 #1 Posted August 3, 2021 Today I was tracking down a noise that I notice coming from the front drive pully on the motor. The small guide held on with two 1/4" bolts has a piece of material that has worn down to the rivets. The rivets are then rubbing on the pully making the noise. I simply removed this guide noise problem solved. Question: What purpose does this guide serve? This pully is not going anywhere. Share this post Link to post Share on other sites
oldredrider 2,553 #2 Posted August 3, 2021 That is not a guide, it's a brake pad. Used to stop pto pulley when disengaged. 3 Share this post Link to post Share on other sites
Jeff-C175 7,207 #3 Posted August 3, 2021 (edited) 2 hours ago, Paul Dietrich said: What purpose does this guide serve? As OldRed sed, it's a brake pad, but honestly, it doesn't really serve THAT much purpose. I bought a new one for mine since it was worn down and took the old one off. Both the old one and the new one are still sitting on my work bench and when I disengage the PTO without the part installed, the deck slows and stops about the same as it always had. I'll put it back on someday 'just because', but IMO it's just not that important a part. If you want a new one, K&B horse parts has them. In our 'vendor' section. @76c12091520h Edited August 3, 2021 by Jeff-C175 Share this post Link to post Share on other sites
oliver2-44 11,272 #4 Posted August 4, 2021 If you don't have an belt driven attachment on the it, the PTO will continue to spin for quite some time if you don't have a brake on it. Share this post Link to post Share on other sites
Jeff-C175 7,207 #5 Posted August 4, 2021 3 hours ago, oliver2-44 said: If you don't have an belt driven attachment on the it, the PTO will continue to spin for quite some time if you don't have a brake on it. True, but I'm not sure that's a problem? Share this post Link to post Share on other sites
