Skipper 1,792 #1 Posted August 3, 2021 Hi Guys I found a replacement for that often faulty fuel level sender that we had trouble replacing. What I have found is a sender meant for marine, and also other applications i guess. It is made of stainless, and has no moving parts in the fuel, except from a magnet in a plastic/foam ring. All the gismos is sealed inside the tube, and as such, this should be very unlikely to fail. It came with correct flange and new rubber gasket, and new fasteners. Seems good quality, and I have no hesitations putting it in. Works perfectly. Here is the spec on the one I got. 175mm, 240-33 ohm. (comes in custom length too, for specific needs) Got mine here for less than 18$, delivered to my door, but I'm sure you can get equivalent many other places.: https://www.aliexpress.com/item/1005001348618484.html?spm=a2g0s.9042311.0.0.27424c4d6vLPM2 Hope this can help someone out there 5 1 Share this post Link to post Share on other sites
lak1965 52 #2 Posted August 28, 2021 Thanks, Just ordered one for myself. Share this post Link to post Share on other sites
