Gregor 4,847 #1 Posted July 30, 2021 I have a set of Wheel Horse wheel weights like these. Or so it would appear. One is heavy, the other is just a plastic shell. Can the empty on be filled? If so, with what? Concrete mix? Seems to me it would take months to set up, but maybe not. Thanks Greg Share this post Link to post Share on other sites
JoeM 8,345 #2 Posted July 30, 2021 You need to break out the bathroom scale and see how much weight is in the one that is filled. If it is 50lbs you will have to add some metal to the concrete mix. Maybe steel shot? Concrete alone is not as heavy as steel or lead. I am going from memory, but I am thinking concrete mix will bring it in at 40 or so pounds. Mix it on the runny side and it will harden in a day or so. 3 Share this post Link to post Share on other sites
lynnmor 7,817 #3 Posted July 30, 2021 2 hours ago, Gregor said: I have a set of Wheel Horse wheel weights like these. Or so it would appear. One is heavy, the other is just a plastic shell. Can the empty on be filled? If so, with what? Concrete mix? Seems to me it would take months to set up, but maybe not. Thanks Greg Concrete will set up without drying, it is a chemical reaction. 5 Share this post Link to post Share on other sites
