upstateyankee50 59 #1 Posted July 28, 2021 I was wondering if any one knows the correct size of the blades on RM -326 mower deck as the ones on now are 16 inches long where my other deck which is a RM-367 which are 18 inches in length ;for a 100 dollars and a 3 hour ride to pick it up ;it was worth the cash Share this post Link to post Share on other sites
Achto 32,095 #2 Posted July 28, 2021 29 minutes ago, upstateyankee50 said: I was wondering if any one knows the correct size of the blades on RM -326 mower deck as the ones on now are 16 inches long where my other deck which is a RM-367 which are 18 inches in length A RM-326 is a 32" cut so two 16" blades should be correct. A RM-367 is a 36" deck and it should have two 18" blades. 1 2 Share this post Link to post Share on other sites
upstateyankee50 59 #3 Posted July 28, 2021 29 minutes ago, Achto said: A RM-326 is a 32" cut so two 16" blades should be correct. A RM-367 is a 36" deck and it should have two 18" blades. thanks so much as I wasn't sure if the ones on the 326 were correct 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,355 #4 Posted July 29, 2021 Click on the pictures in the links The blades are listed on the page that comes up. 1 Share this post Link to post Share on other sites
upstateyankee50 59 #5 Posted July 30, 2021 On 7/28/2021 at 7:13 PM, gwest_ca said: Click on the pictures in the links The blades are listed on the page that comes up. thank you for the down loads as to the blades ;it seems that the ones on the RM-326 are the correct ones 'they are some what rusted but still sharp; I thought both decks were the same even with different numbers ; but after one member explained the difference in the pan size of only 4 inches I wasn't' sure if the blades should be the same size as the other deck I have; as one is a 32 inch cut where the other is a 36 inch cut but viewing the both together and really seeing they are both the same it seems I did get confused 'but at least I have a parts deck if it ever comes to that point ;I bought the tractor a few years back for 75 dollars and thought that I made a good deal; but the thing is I do not have a clue as the motor horse power as there are no numbers to search ;it has the Briggs motor on it and a pull start ;I believe the motor is not the correct one ;as it is a pull start with the electronic ignition which has been replaced to a new one ;as well both choke and throttle cables are new ;it will start on the 2nd pull and runs fast with the automatic transmission ;still being an older wheel horse it was worth the 75 ; Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,355 #6 Posted July 30, 2021 Look up high under the dash panel for an ID plate Share this post Link to post Share on other sites
upstateyankee50 59 #7 Posted August 1, 2021 On 7/30/2021 at 9:55 AM, gwest_ca said: Look up high under the dash panel for an ID plate sorry as I have look every where's for the tag but nothing to be found Share this post Link to post Share on other sites
