Hwhitaker1 1 #1 Posted July 28, 2021 We have a 2002 522xi this just started today when mowing going uphill the engines Boggs down and will die but I can go uphill fine without pto on. If it’s a slight incline if I let up on gas it will kick back in full speed then it made a noise and completely died! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,416 #2 Posted July 28, 2021 Sounds like the seat switch is not staying closed but not the only item that can cause this. I suspect the ignition is being turned off. Very complicated electrical system but these diagrams will walk you through it. Try over riding the MNIR (No mow in reverse) to see if that changes things. Post your comments. Garry 1 Share this post Link to post Share on other sites
Hwhitaker1 1 #4 Posted July 28, 2021 And this is what it sounds like trying to restart it IMG_3323.MOV Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,416 #5 Posted July 28, 2021 Sounds like it has no compression. Turning over too easy. Garry 3 Share this post Link to post Share on other sites
Hwhitaker1 1 #7 Posted July 31, 2021 Yep no compression found some bits of aluminum in the oil ☹️ 2 Share this post Link to post Share on other sites
Hwhitaker1 1 #8 Posted August 2, 2021 Yep no compression found some bits of aluminum in the oil ☹️ Someone had removed the oil sentry so when the oil came out while mowing it didn’t shut off! 2 Share this post Link to post Share on other sites
