Scott 520H 0 #1 Posted July 28, 2021 Tractor turns over great - When turning over the headlights will cut off and the volt meter goes to zero like the battery was suddenly disconnected but it continues to turn over fine at full power ? all lights on the dash come on when turned to on. where should I start troubleshooting? Fuses are all good and connections at fuse block look good Share this post Link to post Share on other sites
Handy Don 14,239 #2 Posted July 28, 2021 (edited) 59 minutes ago, Scott 520H said: Tractor turns over great - When turning over the headlights will cut off and the volt meter goes to zero like the battery was suddenly disconnected but it continues to turn over fine at full power ? all lights on the dash come on when turned to on. where should I start troubleshooting? Fuses are all good and connections at fuse block look good Welcome to the forum. It is correct that headlights and volt meter are off during cranking (why waste juice on them until then engine is running?) and dash lights on (briefly) when switch is ON. Do you have the manual for your year/model (search in the manuals section for something like "tractor 520-H" and switch on "use all search terms") Is it starting to fire up and then not catching? Is it not even trying to start? Is the PTO lever disengaged? Is the motion control lever securely in neutral? If it is cranking, but not starting then the problem is either fuel or spark. Has fuel? Fuel petcock open? If a clear fuel filter, can you see fuel passing through? Smell fuel in exhaust after trying to start? Has spark? (Best to use a spark tester) Edited July 28, 2021 by Handy Don Share this post Link to post Share on other sites
Scott 520H 0 #3 Posted July 28, 2021 getting fuel as i can smell it all levers are in correct position i had the lights on just to see if they dimed or not but they cut clear off as does the voltage meter so i assume it must be electrical someplace Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,560 #4 Posted July 28, 2021 Model year? Model number and serial number? Garry Share this post Link to post Share on other sites
lynnmor 7,903 #5 Posted July 28, 2021 2 hours ago, Scott 520H said: getting fuel as i can smell it all levers are in correct position i had the lights on just to see if they dimed or not but they cut clear off as does the voltage meter so i assume it must be electrical someplace As Don said, lights are turned off while cranking. A quick test for spark is to simply lay a spark plug against a metal part of the engine with a spark plug wire attached, then crank while watching for spark. Share this post Link to post Share on other sites
