wfopete 59 #1 Posted July 23, 2021 Looking at picking up a one owner 1994 416-8. Has 1100 hours on it, original owner. Kohler Power Plus. 48inch deck. Deck has only seen belts and blades and it also has the optional bagging/vac/fan assist unit. Asking price is $900. Owner says the clutch pedal needs adjustment. Overall I like what I see but have not had a in person visit. So 1100 hours is about 1/2 through the average service life for this unit or is it likely on the downside of it's run time? I'm wondering about parts availability for it too. What should I check that might be needing repair/replacement? Thanks. 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #2 Posted July 23, 2021 I have a 416-8 and love it. It is an Onan not a Kohler. The service life is completely dependent on on how well it is maintained. Onan's in welders and generators have excellent reputation's. 3000 hrs is not uncommon. On Garden tractors they are more likely abused than the previous applications and do not like dirty cooling fins. If the cooling fins get dirty from grass, dirt and oil they will run hot and possibly throw a valve seat. I personally like my Onans, I have a p216 and a P220. They sound great, are fairly easy to maintain and parts availability is very good. Keep in mind OEM parts are not cheap but much less than OEM Kohler parts in my opinion. The rest of the tractor is as boollit proof as any Wheel Horse. Good luck. 3 Share this post Link to post Share on other sites
Zeek 2,299 #3 Posted July 24, 2021 (edited) Make sure you know the condition of the deck spindles if they are original with 1100 hrs. I would do that by jacking it up so you can reach the blades and move them (not turn). I doubt you can get enough leverage from the top to check that effectively and just a demonstration of them running may not show that depending on speed/load. That can be a pricy repair, I just did a 54" deck on another brand . . . Edited July 24, 2021 by Zeek Share this post Link to post Share on other sites
clueless 3,438 #4 Posted July 24, 2021 I've got a '97 416-8 (Onan) with 225 hr has the 42"sd deck or the 36" rd deck, the rear rock shaft lift the clevis hitch, new tires, new seat, new battery, and tune up. Second owner, always garaged and maintained, out the door price $1200.00, drive a little save a lot. I'm in Pensacola Fl. take a long weekend and enjoy one of the best beaches in the world . 3 Share this post Link to post Share on other sites
Dan.gerous 2,696 #5 Posted July 24, 2021 I have a lovely one with the Onan engine, only issue is some electrical gremlin that is stopping it start at the moment. When it's up and running it's a thing of beauty and sounds awesome. Share this post Link to post Share on other sites
tom2p 2,396 #6 Posted July 24, 2021 1 hour ago, clueless said: I've got a '97 416-8 (Onan) with 225 hr has the 42"sd deck or the 36" rd deck, the rear rock shaft lift the clevis hitch, new tires, new seat, new battery, and tune up. Second owner, always garaged and maintained, out the door price $1200.00, drive a little save a lot. I'm in Pensacola Fl. take a long weekend and enjoy one of the best beaches in the world . If I lived close I would be tempted to buy it - even though I have two 416-H If you cut a lot of grass - the Onan twins (and Kohler twins) are a game changer 1 Share this post Link to post Share on other sites
tom2p 2,396 #7 Posted July 24, 2021 (edited) 23 hours ago, wfopete said: Looking at picking up a one owner 1994 416-8. Has 1100 hours on it, original owner. Kohler Power Plus. 48inch deck. Deck has only seen belts and blades and it also has the optional bagging/vac/fan assist unit. Asking price is $900. Owner says the clutch pedal needs adjustment. Overall I like what I see but have not had a in person visit. So 1100 hours is about 1/2 through the average service life for this unit or is it likely on the downside of it's run time? I'm wondering about parts availability for it too. What should I check that might be needing repair/replacement? Thanks. if the tractor sat outside or in a damp area - probably better to pass on it Onan powered Wheel Horse tractors especially are prone to all sorts of gremlins when not stored inside at 1000 hours - if valve adjustment was not done it is past due *** - prob good idea to do a compression check (to check for possible valve / valve seat issue) ... and should then also factor into the price *** also heads / piston tops should be decarboned Edited July 24, 2021 by tom2p Share this post Link to post Share on other sites
wfopete 59 #8 Posted July 24, 2021 (edited) Well I took a look at it and mechanically it wasn't too bad but you could tell it wasn't taken care of. I mean it ran well and cut decent but there were several telltale signs of neglect. Tires were well worn and dry rotted, scratches, rust and dents on the sheet metal. A couple half-ass DIY repairs were evident also. The owner wasn't the sharpest knife in the drawer either 🔪. The search continues. Edited July 25, 2021 by wfopete 1 Share this post Link to post Share on other sites
ohiofarmer 3,475 #9 Posted July 26, 2021 (edited) I have a 416-8 that is a garage queen with not many hours. However it makes a squealing sound that I cannot locate, so it got parked in a nice wood floor garage./shop. Maybe a bearing, I do not know. The mower deck is still in paint on the bottom.... I need an Onan guru, I suppose. I am just afraid to run it in case it might be a crankshaft problem Edited July 26, 2021 by ohiofarmer Share this post Link to post Share on other sites
johnnymag3 2,646 #10 Posted July 26, 2021 Good move......I prefer Kohler over Onans, but it is always dependent on Owners care or lack thereof that gives them a long life !! JMO John Share this post Link to post Share on other sites
wfopete 59 #11 Posted July 26, 2021 (edited) I found another one at a better price ($500). The Onan has been rebuilt but I don't know how long ago. Looks complete and better than the one before but certainly not a Garage Queen. It's a suburbia unit so probably not pushed too hard but it will be a couple of weeks before I can peek at it. When I worked for Toro/Wheel Horse in the early 90's I remember the Onans losing their lower ends. Can't remember the exact problem or cause; as the saying goes: "I've slept since then". I could settle for a nice 300 eight speed "Classic" series but I'd like to get something a little bigger. Deep down I'm a Round Hood fan but I prefer a bit more power and size. I have a C-111 eight speed with a dead Briggs I could get motivated to repair but it only has a 36" RD deck besides I need something I can use now. I fear my little Troy Bilt Pony has got about 5 years of steady use is probably getting close to imploding. Edited July 26, 2021 by wfopete Share this post Link to post Share on other sites
Bill D 3,140 #12 Posted July 26, 2021 1 hour ago, ohiofarmer said: I have a 416-8 that is a garage queen with not many hours. However it makes a squealing sound that I cannot locate, so it got parked in a nice wood floor garage./shop. Maybe a bearing, I do not know. The mower deck is still in paint on the bottom.... I need an Onan guru, I suppose. I am just afraid to run it in case it might be a crankshaft problem Check the drive belt idler pulley. Also, check the bearings in the PTO. Share this post Link to post Share on other sites
ohiofarmer 3,475 #13 Posted July 26, 2021 (edited) 5 hours ago, Bill D said: Check the drive belt idler pulley. Also, check the bearings in the PTO. This is definitely within the engine block. The 416 was way overfilled with oil when i got it and there was an oil puking event in the side ditch. This was a new tractor, so I drained it and changed it just in case and there were no issues. One of those things that you do not think about. In reality I never used it much and kept it nice with just a bit of honest wear. The sound almost reminds you of a pulley rubbing on something ...not squealin like a bearing. Good suggestion though. I recon that I could just hook the engine up without the drive pulley or transmission belt installed. Thanks Edited July 26, 2021 by ohiofarmer Share this post Link to post Share on other sites
Bill D 3,140 #14 Posted July 26, 2021 4 hours ago, ohiofarmer said: This is definitely within the engine block. The 416 was way overfilled with oil when i got it and there was an oil puking event in the side ditch. This was a new tractor, so I drained it and changed it just in case and there were no issues. One of those things that you do not think about. In reality I never used it much and kept it nice with just a bit of honest wear. The sound almost reminds you of a pulley rubbing on something ...not squealin like a bearing. Good suggestion though. I recon that I could just hook the engine up without the drive pulley or transmission belt installed. Thanks If that checks out, then consider pulling the flywheel and checking the condition of the magnets and stator. Share this post Link to post Share on other sites
