Jack Orsi 2 #1 Posted July 14, 2021 Has anyone repacked the wheel bearings on their 520xi? If so how often? Share this post Link to post Share on other sites
Jack Orsi 2 #2 Posted July 14, 2021 Don't know why this appears in electrical Share this post Link to post Share on other sites
Shynon 7,541 #3 Posted July 15, 2021 5 hours ago, Jack Orsi said: Has anyone repacked the wheel bearings on their 520xi? If so how often? front wheel bearings are sealed bearings Share this post Link to post Share on other sites
roadapples 6,986 #4 Posted July 15, 2021 13 minutes ago, Shynon said: front wheel bearings are sealed bearings Not on 520, don't know about xi.... Share this post Link to post Share on other sites
lynnmor 8,577 #5 Posted July 15, 2021 The 520 has grease fittings or you can hand pack. If you use the grease fitting, it is easy to push the grease seal right out. The 520xi appears to have sealed bearings, why not just pop one out to see if you can add grease? Share this post Link to post Share on other sites
Shynon 7,541 #6 Posted July 15, 2021 13 hours ago, roadapples said: Not on 520, don't know about xi.... Yes you are correct on the 520, the question is about a 520xi which is sealed. 1 Share this post Link to post Share on other sites
Jack Orsi 2 #7 Posted July 17, 2021 Thanks for your input. I have the original manual and there's no mention of maintenance of wheel bearings. Never occurred to me that they might be sealed. Makes sense. It does mention checking toe in etc so would think if bearings needed attention it would be mentioned. Share this post Link to post Share on other sites
