Felix 145 #1 Posted July 14, 2021 Hi guys. I’ve acquired a c120 auto that needs a fair amount of work. Engine not running but looks in good order. the half shaft also keeps popping out of the left hand side. I’m wondering if the 12hp Kohler engine will fit straight in my B80 4 speed with out any mods. I’m thinking I could make one nice tractor out of the pair I have. Here’s a picture of them both. 4 1 2 Share this post Link to post Share on other sites
Maxwell-8 4,371 #2 Posted July 14, 2021 (edited) 5 minutes ago, Felix said: the half shaft also keeps popping out of the left hand side drive shaft? busted c-clip, bougth a 314 with the same issue, just open the tranny and install a new C-clip. Kohler should just swap over. Edited July 14, 2021 by Maxwell-8 3 Share this post Link to post Share on other sites
ebinmaine 80,640 #3 Posted July 14, 2021 Agreed. Felix I'd fix them both. 7 minutes ago, Felix said: I’m thinking I could make TWO nice tractors out of the pair I have Fix/save/keep both. Parts are readily available. 5 Share this post Link to post Share on other sites
Felix 145 #4 Posted July 14, 2021 It’s getting the hubs of the half shafts that putting me of. Is it easy to get to the c clip once the case is split in half? Share this post Link to post Share on other sites
Maxwell-8 4,371 #5 Posted July 14, 2021 1 minute ago, Felix said: It’s getting the hubs of the half shafts that putting me of. Is it easy to get to the c clip once the case is split in half? yes, look out for the old c-clip still laying in the tranny some where. Make yourself a good puller, the guy before you probably used a hammer, banging the clip out. Share this post Link to post Share on other sites
Felix 145 #6 Posted July 14, 2021 I forgot to mention I’m the other side of the pond to most of you on here. 👍🏻👍🏻🚜💨 1 Share this post Link to post Share on other sites
Felix 145 #7 Posted July 14, 2021 2 minutes ago, Maxwell-8 said: yes, look out for the old c-clip still laying in the tranny some where. Make yourself a good puller, the guy before you probably used a hammer, banging the clip out. Would I need to remove both hubs or just the side with the problem? Share this post Link to post Share on other sites
Maxwell-8 4,371 #8 Posted July 14, 2021 Can you take the axle out all the way? Just now, Felix said: Would I need to remove both hubs or just the side with the problem? Share this post Link to post Share on other sites
Felix 145 #9 Posted July 14, 2021 Not had it all way out but it came a long way out when I was. Towing it. It went back in easy. Share this post Link to post Share on other sites
Maxwell-8 4,371 #10 Posted July 14, 2021 (edited) 2 minutes ago, Felix said: Not had it all way out but it came a long way out when I was. Towing it. It went back in easy. You will have to take off both hubs, but once you have a good puller it's a breeze. Edited July 14, 2021 by Maxwell-8 Share this post Link to post Share on other sites
Felix 145 #11 Posted July 14, 2021 Just now, Maxwell-8 said: You will have to take off both hubs, but once you have a good puller it's a breeze. Thanks for your help I’ll keep you posted. Going to try and get engine running and see if it has any drive first. 👍🏻👍🏻 Share this post Link to post Share on other sites
Maxwell-8 4,371 #12 Posted July 14, 2021 2 minutes ago, Felix said: Thanks for your help I’ll keep you posted. Going to try and get engine running and see if it has any drive first. 👍🏻👍🏻 Be carfull when you go drive it, the C-clip is still in there, so It doesn't end up damaging any gears. would get the tranny fixed before a drive. 2 1 Share this post Link to post Share on other sites
Achto 32,633 #13 Posted July 14, 2021 If you can slide the one axle all of the way out, you can use a press to remove that hub. Definitely fix the tranny before trying to put power to it. 2 1 Share this post Link to post Share on other sites
Gregor 4,848 #14 Posted July 14, 2021 2 hours ago, Felix said: I’m thinking I could make one nice tractor out of the pair I have. Seems to me you already have 2 nice tractors. One of them simply needs a little TLC. Why settle for one, if you can have 2? 1 1 Share this post Link to post Share on other sites
Racinbob 13,135 #15 Posted July 14, 2021 I'm in total agreement with the others. The axle is a simple fix. If you still want to do the swap it's quite easy. Do not use the riser plate that the K-181 sits on. Use the PTO from the K-341.There's a bearing race inside for the larger shaft. A little bit of tinkering with the control cables and you're off and running. Here's my "B-160". I bought it new as a B-80 and swapped in a K-341. 3 3 Share this post Link to post Share on other sites
953 nut 69,147 #16 Posted July 14, 2021 2 hours ago, Felix said: Would I need to remove both hubs or just the side with the problem? Here is a video from one of our members from your side of the pond, next is a thread on the transmission. 3 Share this post Link to post Share on other sites
