lynnmor 8,915 #26 Posted July 26, 2021 12 hours ago, kawimaniac2145 said: it still surges at high rpm and how do i adjust it. Was the welch plug missing? Did you clean all the small holes behind it? There is no adjustment for high speed mixture, only the idle mixture if it has a idle mixture screw. To adjust the idle, do this: 1. Back off the idle adjustment screw located near the throttle cable. 2. Adjust the throttle stop screw for 1000 RPM. 3. Adjust idle mixture screw for the highest speed and best idle. 4. Readjust the throttle stop screw to 1000 RPM if necessary 5. Readjust the mixture if necessary. 6. Repeat steps 4 & 5 if necessary. 7. Adjust the idle adjustment screw near the throttle cable to 1200 to 1400 RPM. 8. Insure that the throttle cable pushes the lever to the stop, the speed should be 3600 RPM, bend the stop if needed. If you still have problems, check for damage, adjust the float level and clean the carburetor. Share this post Link to post Share on other sites
kawimaniac2145 6 #27 Posted July 26, 2021 there is no damage. and the float is level with the base of the carb. mine has a screw below the carb. is that the mixture screw. and if it is. how do i get to it. the muffler is in the way? Share this post Link to post Share on other sites
WheelHorse520H 710 #28 Posted July 27, 2021 21 hours ago, kawimaniac2145 said: there is no damage. and the float is level with the base of the carb. mine has a screw below the carb. is that the mixture screw. and if it is. how do i get to it. the muffler is in the way? I believe you have to take the muffler off. Not sure if that is the screw you need or not but I would take the muffler off. Share this post Link to post Share on other sites
lynnmor 8,915 #29 Posted July 27, 2021 23 hours ago, kawimaniac2145 said: there is no damage. and the float is level with the base of the carb. mine has a screw below the carb. is that the mixture screw. and if it is. how do i get to it. the muffler is in the way? The float level adjustment is on page 7-3 of the Onan Service Manual. The idle mixture screw can be adjusted with a long skinny screwdriver at a bit of an angle, there is no need to remove anything. Example of a screwdriver that is much longer than you really need, but will work fine. A flashlight helps to locate the screw. Share this post Link to post Share on other sites
kawimaniac2145 6 #30 Posted July 27, 2021 do all of you think it can be that the intake manifold gasket material could be allowing air to get sucked in Share this post Link to post Share on other sites
lynnmor 8,915 #31 Posted July 28, 2021 2 hours ago, kawimaniac2145 said: do all of you think it can be that the intake manifold gasket material could be allowing air to get sucked in Did you replace them and use genuine Onan gaskets? Is so, did you use a torque wrench? Usually a leak there would cause more problems at idle than high speed. Share this post Link to post Share on other sites
kawimaniac2145 6 #32 Posted July 28, 2021 19 hours ago, lynnmor said: Did you replace them and use genuine Onan gaskets? Is so, did you use a torque wrench? Usually a leak there would cause more problems at idle than high speed. i was talking on the intake manifold itself. Share this post Link to post Share on other sites
lynnmor 8,915 #33 Posted July 29, 2021 4 hours ago, kawimaniac2145 said: i was talking on the intake manifold itself. There are three gaskets, two where it attaches to the engine block and one where the carburetor attaches. The intake manifold is two pieces with a sealant between the two. The test by spraying carb cleaner was discussed earlier. 1 Share this post Link to post Share on other sites
