dkg520 531 #1 Posted July 4, 2021 I’m getting gas and spark. It rolls over but will not fire. What am I missing? Thanks. Share this post Link to post Share on other sites
johnnymag3 2,647 #2 Posted July 4, 2021 What engine is in it? Share this post Link to post Share on other sites
johnnymag3 2,647 #3 Posted July 4, 2021 Fuel and Spark equal FIRE......is the Carb all out of sorts???? Flooding the plug?? Share this post Link to post Share on other sites
johnnymag3 2,647 #5 Posted July 4, 2021 21 minutes ago, dkg520 said: It’s a 14 Kohler What Kohler? K....Magnum....something else? john Share this post Link to post Share on other sites
dkg520 531 #6 Posted July 4, 2021 Not a magnum On a 1986 414-8 Share this post Link to post Share on other sites
8ntruck 9,068 #7 Posted July 4, 2021 New spark plug? My chipper/shredder was not starting easily. Installed a new plug, starts on first pull now. Spark happening at the right time? Got compression? Though it probably has compression release, so that is hard to measure. Is gas getting into the cylinder? Share this post Link to post Share on other sites
squonk 47,422 #8 Posted July 4, 2021 (edited) A cylinder under pressure needs more voltage to fire the plug as opposed to having the plug laying on the cylinder head or using a spark tester. Could be the plug,wire,coil. Or the compression is low or timing off. Edited July 4, 2021 by squonk 2 Share this post Link to post Share on other sites
dkg520 531 #9 Posted July 4, 2021 Changed the coil and put in a new plug. It took right off. Thank you all! 3 Share this post Link to post Share on other sites
pfrederi 20,891 #10 Posted July 4, 2021 Great!! But don't junk that old coil would be willing to bet it was the plug. Coils fail out right (unusual) or act up when they get hot. You can test them. 4 Share this post Link to post Share on other sites
