JimM 0 #1 Posted July 2, 2021 Hi all. First post since re-joining. I was a member some years ago, then the forum moved or something and I got lost. Anyway, I have a Raider 10 with the teccy. Been sitting for several years, along with all my stuff. Trying one by one to get them going. This unit, of course, needs a new battery. Took the old one out, went to install new one, and realized the old one had apparently had the positive post grounded to the frame. Is this at all normal for one of this model? I’m unsure how to hook up the cables now. Any advice would certainly be appreciated. Thank you, Jim Share this post Link to post Share on other sites
Jeff-C175 7,211 #2 Posted July 2, 2021 (edited) Hi Jim, welcome back! You might want to download the manual for your machine but I'm pretty sure it's not a positive ground system! Someone who knows for sure will be along shortly. Edited July 2, 2021 by Jeff-C175 Share this post Link to post Share on other sites
squonk 48,156 #3 Posted July 2, 2021 No Wheel Horse tractor was positive ground. They do make those tractor batteries with the terminals reversed. 5 Share this post Link to post Share on other sites
JimM 0 #4 Posted July 2, 2021 Thanks guys. I have an exact match to the old battery. Same terminal location. I’m fairly certain I removed said old battery and placed it on the grass in the same orientation as it came off of the tractor. Plus terminal towards me. Which indicated to me the wire on that side was to the frame. I don’t know. I’m getting old. I’ll hook it up tomorrow as I think it should be and see what happens. I’ll keep the fire extinguisher handy. Lol Again, thanks. I had never seen a positive ground on a WH before, but I’m mostly a dummy. Share this post Link to post Share on other sites
lynnmor 9,042 #5 Posted July 2, 2021 DO NOT connect the positive terminal to ground. The previous owner may have purchased the wrong battery and that is why the tractor was out of service. 1 Share this post Link to post Share on other sites
oliver2-44 11,758 #6 Posted July 2, 2021 7 hours ago, lynnmor said: DO NOT connect the positive terminal to ground. The previous owner may have purchased the wrong battery and that is why the tractor was out of service. Share this post Link to post Share on other sites
