Sarthurs01 1,024 #1 Posted July 1, 2021 I have a 4hp Kohler on my one rj that always fired right up on the first pull and went to start it last weekend and theres no spark. I tryed cleaning the points last night still nothing. what else can I check and what will it take to do it? Thanks! Share this post Link to post Share on other sites
Achto 30,488 #2 Posted July 1, 2021 Possibly a broken spark plug wire or a bad coil. You would have to pull the engine shroud and fly wheel off to check these out. 1 Share this post Link to post Share on other sites
Sarthurs01 1,024 #3 Posted July 1, 2021 2 hours ago, Achto said: Possibly a broken spark plug wire or a bad coil. You would have to pull the engine shroud and fly wheel off to check these out. Thanks! What all installs on pulling the flywheel? 1 Share this post Link to post Share on other sites
Gregor 4,847 #4 Posted July 1, 2021 If you don't have a flywheel puller, I would suggest taking it to a shop. You could easily make a bad situation a lot worse. 4 Share this post Link to post Share on other sites
c-series don 10,951 #5 Posted July 1, 2021 12 minutes ago, Gregor said: If you don't have a flywheel puller, I would suggest taking it to a shop. You could easily make a bad situation a lot worse. Yes I can attest to that! 1 Share this post Link to post Share on other sites
