Bill Winn 157 #1 Posted June 30, 2021 Good evening, so updates on my C175: Parking brake now works, thanks Jeff-C175. Replacement fender pan on the way, thanks Jeff-C175 and Lincoln New hub set screws and seals on the way, thanks elcamino/wheelhorse et al. New rear blade tach-o-matic mount on the way. So here's the issue I looked at today when I got some free time... When I got this tractor I noticed that it speeds up going down hill and the speed control lever does not stay in place on its own. I have to hold it in place or it will slow down significantly. Is there an adjustment on the top of the hydro? I did read through Scotty's post about his hydro woes with his 416h so it reads like I may have a compound issue.... one with the speed control remaining set and the other with the downhill acceleration. Could it be as simple as a new belt and a tightening a bolt or nut? I've included a lettered picture of the hydro linkage on top of the unit. Bill Share this post Link to post Share on other sites
Jeff-C175 7,207 #2 Posted June 30, 2021 Bill, do you have the Sundstrand or the Eaton tranny? @Bill Winn Share this post Link to post Share on other sites
Bill Winn 157 #3 Posted June 30, 2021 Just now, Jeff-C175 said: Bill, do you have the Sundstrand or the Eaton tranny? @Bill Winn Dunno? How do I tell? Share this post Link to post Share on other sites
Jeff-C175 7,207 #4 Posted June 30, 2021 (edited) 2 minutes ago, Bill Winn said: Dunno? How do I tell? Is your filter on the right side or on the rear? Also, if there's an S after the K in the model number it's a Sunny, if an E, an Eaton. Edited June 30, 2021 by Jeff-C175 Share this post Link to post Share on other sites
Bill Winn 157 #5 Posted June 30, 2021 1 minute ago, Jeff-C175 said: Is your filter on the right side or on the rear? Just went out to check. It's on the rear left. Share this post Link to post Share on other sites
JAinVA 4,638 #6 Posted June 30, 2021 Hydros will speed up going down hill. They shouldn't get crazy fast but they do speed up. Gradually tighten up nut D. This adjustment will regulate the speed setting. Under no circumstances put any lubricant on this washer assembly. Luck,JAinVA Share this post Link to post Share on other sites
Bill Winn 157 #7 Posted June 30, 2021 1 minute ago, JAinVA said: Hydros will speed up going down hill. They shouldn't get crazy fast but they do speed up. Gradually tighten up nut D. This adjustment will regulate the speed setting. Under no circumstances put any lubricant on this washer assembly. Luck,JAinVA Thanks and the VIN does have an E after the K. Is one brand better than the other? Share this post Link to post Share on other sites
JCM 10,411 #8 Posted June 30, 2021 I have 3 Eatons and they are bulletproof IMO. I know nothing about Sundstrands. Good luck 1 Share this post Link to post Share on other sites
JAinVA 4,638 #9 Posted June 30, 2021 (edited) The transaxle you have is an Eaton 1100. The Sunstrand is a good transaxle but the Eaton might be easier to find if you need to replace the one you have. Like JCM I have several Eatons and have had no issues with any of them. Edited June 30, 2021 by JAinVA 2 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #10 Posted June 30, 2021 And likewise my Sundstrand keeps on tickin' I think they're pretty much the same reliability wise. 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,842 #11 Posted June 30, 2021 Click on the picture in the link Garry 1 Share this post Link to post Share on other sites
tom2p 2,394 #12 Posted June 30, 2021 as suggested above - tighten nut 'D' you can also add an additional nut on top of the original nut ... (nylock or similar even better) ... most (all ?) Eaton 1100 hydros will pick up speed as you head down a grade ... just tap the speed control lever lightly to reduce speed and stop the freewheeling Eaton 1100 hydro is very durable / reliable 2 Share this post Link to post Share on other sites
squonk 44,860 #13 Posted June 30, 2021 Check the piece under the plate at point B. That slot in the plate will wear a groove in it throwing off the adjustment. 1 Share this post Link to post Share on other sites
Tuneup 1,452 #14 Posted June 30, 2021 What Squonk said! My 515 was so worn, there was no adjustment that would last. I bought a replacement plate and adjuster but the adjuster wouldn't run in the plate without my getting a grinder on that plate all around the travel surface - the plate coating catched on the nut. Quality isn't what it once was. I adjust it while standing behind the tractor, full throttle and warm. 2 Share this post Link to post Share on other sites
Handy Don 15,162 #15 Posted June 30, 2021 9 hours ago, Tuneup said: I adjust it while standing behind the tractor, full throttle and warm With the wheels OFF THE GROUND, right? 1 Share this post Link to post Share on other sites
Tuneup 1,452 #16 Posted June 30, 2021 Of course not . I'm the type that has to get something in my eye before I wear safety glasses - an accident waiting to happen. I actually did just that adjustment today. The 516 did a nice job on the lawn today but the slowness of reverse is a bother. I pulled the plate and ground it a bit for more travel. You can get just a little before it hits the bracket. Put it in assumed neutral and started it at low idle. It crept forward. Nut adjust and done. I do use jack stands and or ramps when under the Ford - have since a teen. My stupidity does have its bounds. 1 Share this post Link to post Share on other sites
seuadr 489 #17 Posted July 1, 2021 18 hours ago, Handy Don said: With the wheels OFF THE GROUND, right? i was picturing him running along behind 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #18 Posted July 1, 2021 17 hours ago, Tuneup said: My stupidity does have its bounds. Mine doesn't. 1 Share this post Link to post Share on other sites
Handy Don 15,162 #20 Posted July 1, 2021 11 minutes ago, tom2p said: Applicant for Darwin Award.... 1 Share this post Link to post Share on other sites
Tuneup 1,452 #21 Posted July 5, 2021 C'mon, give him credit. He's got it almost to the balance point so there's not much on those 4x4s. 2x4s would have been sufficient. The man must be an engineer. That's not me, though. I have my limits. 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #22 Posted July 5, 2021 3 minutes ago, Tuneup said: not much on those 4x4s Except for the fact that they are probably Balsa Wood! Share this post Link to post Share on other sites
Handy Don 15,162 #23 Posted July 5, 2021 8 hours ago, Tuneup said: C'mon, give him credit. He's got it almost to the balance point so there's not much on those 4x4s. 2x4s would have been sufficient. The man must be an engineer. That's not me, though. I have my limits. 8 hours ago, Jeff-C175 said: Except for the fact that they are probably Balsa Wood! Yep, I can see the engineer now..he pushes the wrench a bit too hard, the 4x4's drop to the ground and he's left balancing the car with his hands! 1 Share this post Link to post Share on other sites
