Jeff1129 108 #1 Posted June 29, 2021 I would like to convert halogen to led lights on my 520hc i would prefer Amazon links but anything works thanks Jeff Share this post Link to post Share on other sites
Andy N. 2,824 #2 Posted June 29, 2021 For my '80's tractors listed in my signature, I used the following: https://www.amazon.com/gp/product/B07R88B64W/ref=ppx_yo_dt_b_asin_title_o00_s02?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00VT85Q0G/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 I mounted the tail lights with small bolt and nut and put a small loop connector on the ground and attached it under the nut. Head lights were a direct replacement for me. 1 Share this post Link to post Share on other sites
pfrederi 21,177 #3 Posted June 29, 2021 or these https://www.amazon.com/dp/B07SX1DV4R/?coliid=IK4B5U2DMRWIA&colid=14RFMLBGX6MBD&psc=1&ref_=lv_ov_lig_dp_it 1 Share this post Link to post Share on other sites
Handy Don 17,490 #4 Posted June 29, 2021 11 minutes ago, pfrederi said: or these https://www.amazon.com/dp/B07SX1DV4R/?coliid=IK4B5U2DMRWIA&colid=14RFMLBGX6MBD&psc=1&ref_=lv_ov_lig_dp_it I put on a set of these. The beam is a bit more concentrated in the middle and throws a bit farther than the LED flood style. Also the 5000k is a bit less blue/white than the 6000k -- personally I prefer this. Share this post Link to post Share on other sites
Tuneup 1,459 #5 Posted July 10, 2021 5000K would be fun! Just remember that, in China, 2 years is the same as 2 months so your actual warranty performance may vary. What else is there nowadays? My 516 lamps are just dull - may do this as well. Share this post Link to post Share on other sites
peter lena 10,076 #6 Posted July 10, 2021 @Jeff1129, noting your planned lighting upgrade . since going after all my grounding areas , everything is better , this is an easy up grade you might try , first and last picture , the battery ground rail cable mount , and the lower engine mount to frame area. add a 4 ga cable and connect those 2 points , also go over all your connections , do not be afraid to add a few other ground wires to anything that is not solid , dielectric grease on every bolt down . just a suggestion , pete Share this post Link to post Share on other sites
