Pullstart 70,036 #26 Posted June 25, 2021 Cool muffler indeed! If you ever get tired of looking at that thing... I have just the machine for it! I’m not sure which one yet, but I’ll figure it out.. 1 Share this post Link to post Share on other sites
Graham529 16 #27 Posted June 28, 2021 Hi Again, Anyone be able to help with a parts manual for the mower deck from my wheel horse? I see there are quite a few variations! Any help would be very much appreciated. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,260 #28 Posted June 30, 2021 On 6/28/2021 at 7:10 AM, Graham529 said: Hi Again, Anyone be able to help with a parts manual for the mower deck from my wheel horse? I see there are quite a few variations! Any help would be very much appreciated. Which deck do you have? 3 blades? 36" width of cut 42" width of cut 48" width of cut Side or rear discharge? Rear depth of cut adjuster on the left side or the right side? Garry Share this post Link to post Share on other sites
Graham529 16 #29 Posted July 1, 2021 Hi Garry, Its a 3 blade, 36 inch cut reach discharge. I have attached a picture, there is no serial numbers visible. many thanks Graham Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,260 #30 Posted July 1, 2021 Here is a list of the decks in the order they were produced Mower DNA 1972 model 5-0620 replaced by 1973-1974 model 5-0621 1975 model 5-0622 1976 model 65-36XR01 1977 model 75-36XR01 1977 model 75-36XR02 1978 model 85-36MR01 1979 model 95-36MR00 (Blades up to this point have the 5/8" x 3/4" double-D center hole unless the spindle has been upgraded) --------------------------------------------------------------------------------------------------------------------------------------------------------------------------- (These decks used blades with a 3/4" center hole) 1979 model 95-36MR01 replaced by 1980-1982 model 05-36MR01 - Last year for bearings with 3/4" ID 1983-84 model 05-36MR02 - First year for bearings with 17mm ID unless older spindles were updated. 1985 model 05-36MR03 1986-1990 model 05-36MR04 1991-1993 model 05-36MR05 1993-2006 model 78305 1 Share this post Link to post Share on other sites
Graham529 16 #31 Posted July 2, 2021 On 7/1/2021 at 1:07 PM, gwest_ca said: Here is a list of the decks in the order they were produced Mower DNA 1972 model 5-0620 replaced by 1973-1974 model 5-0621 1975 model 5-0622 1976 model 65-36XR01 1977 model 75-36XR01 1977 model 75-36XR02 1978 model 85-36MR01 1979 model 95-36MR00 (Blades up to this point have the 5/8" x 3/4" double-D center hole unless the spindle has been upgraded) --------------------------------------------------------------------------------------------------------------------------------------------------------------------------- (These decks used blades with a 3/4" center hole) 1979 model 95-36MR01 replaced by 1980-1982 model 05-36MR01 - Last year for bearings with 3/4" ID 1983-84 model 05-36MR02 - First year for bearings with 17mm ID unless older spindles were updated. 1985 model 05-36MR03 1986-1990 model 05-36MR04 1991-1993 model 05-36MR05 1993-2006 model 78305 That's brilliant! thanks so much for the information its much appreciated Share this post Link to post Share on other sites
