mcwh1950 2 #1 Posted June 9, 2009 i know i read it some where here on red square, but every time i try to search for it i can not find it . i would like to change the point on the c-81, but i not for sure of the button should be in or out all help would be wonderful Share this post Link to post Share on other sites
oldandred 15 #2 Posted June 9, 2009 thats a kill button should be out all the time when pushed in the engine will stop what it does is ground out the points after you change the points be sure there a gasket on there Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #3 Posted June 9, 2009 There shouldn't even be a "kill" button on a C-81. The engines with magneto ignition are the only ones you ground to stop. Grounding the 12VDC power on a battery ignition system is otherwise know as a DEAD SHORT and tends to blow fuses and/or melt wires. :thumbs: Share this post Link to post Share on other sites
