peter lena 9,768 #1 Posted June 17, 2021 last year i started using rislone , zinc additive to all my small engines , now having put hours and oil changes with the same rislone additive , not only do the engines run with out effort , but , my oil dip stick inspection , tube and dipstick are totally clean and clear of the typical milky tube residue. https://rislone.com/product/3x-concentrated-engine-oil-supplement-with-zinc-treatment-4405/?gclid=Cj0KCQjw5auGBhDEARIsAFyNm9Hg6_3LD0791bahLNB9zTrEJK1g4tzlTmJDb_nK1BE1GGRSZkPCK8YaAhOOEALw_wcB , I am not making this up , but letting you know of its improvement to engine cleanliness, worth a try ,use it with rotella 30# . like anything else , its not an instant improvement , how could it be ? but hours and use have proven to me , like my sta bil to all my gas top offs , just my experience . but it works for me , pete 5 Share this post Link to post Share on other sites
Skwerl58 792 #2 Posted June 17, 2021 Interesting observation about the Zinc additive. I also started using it in the past year due to recommendations from here. I check my oil before each use and noticed that my oil is still clear after six weeks or about 10 hours use. I don't understand the science behind some additives but I have seen how some additives do make a difference. 1 Share this post Link to post Share on other sites
peter lena 9,768 #3 Posted June 18, 2021 @ SKWER158. that's what I started to notice after some hours of use , the first thing I really sensed was the ease of running , now I just marvel at how smooth it is at cutting or plowing with little effort. just thought I would pass it on , pete 1 Share this post Link to post Share on other sites
richmondred01 2,333 #4 Posted June 18, 2021 6 hours ago, peter lena said: last year i started using rislone , zinc additive to all my small engines , now having put hours and oil changes with the same rislone additive , not only do the engines run with out effort , but , my oil dip stick inspection , tube and dipstick are totally clean and clear of the typical milky tube residue. https://rislone.com/product/3x-concentrated-engine-oil-supplement-with-zinc-treatment-4405/?gclid=Cj0KCQjw5auGBhDEARIsAFyNm9Hg6_3LD0791bahLNB9zTrEJK1g4tzlTmJDb_nK1BE1GGRSZkPCK8YaAhOOEALw_wcB , I am not making this up , but letting you know of its improvement to engine cleanliness, worth a try ,use it with rotella 30# . like anything else , its not an instant improvement , how could it be ? but hours and use have proven to me , like my sta bil to all my gas top offs , just my experience . but it works for me , pete Use the zinc additive and Rotella 30 in all my rebuilds and my flathead Ford too. 1 1 Share this post Link to post Share on other sites
8ntruck 8,606 #5 Posted June 18, 2021 The zinc additive improves the extreme pressure performance of the oil. It makes the oil film between the mating surfaces in the engine (rods & cranks, lifters & cam, etc) able to keep the mating surfaces separated under higher loads. Zinc has been reduced or removed from modern engine oils to make them more environmentally friendly and to work better with the newer low friction designs of the newer engines. 3 Share this post Link to post Share on other sites
