chev0545
314-8
chev0545
have this 98 314 ohv when i go to start it after i push the choke off will run a bit then backfire & shut off ideas
thanks
Maxwell-8
thanks
Which engine does it have?  they are normally flatheads (no OHV)
Probably needs a good carb clean.
chev0545
98 has a ohv
Maxwell-8
35 minutes ago, chev0545 said:
98 has a ohv
That is correct
Is the backfire from the exaust side or intake.  Intake= rich  exaust= to lean. try and run it on 1/4 choke. Probably the carb has a small piece of debris in the idle circuit.
