Brockport Bill 1,940 #1 Posted June 11, 2021 on the Interchangability chart it shows a 42 inch rear discharge # 0542mr04 fitting a 520HC -- but a few years later after 88-89 of course, the 520HC isn't listed - so my question is.... the 90's mower version of 42 inch RD is model 78355 - does that fit to a 520 HC ? I assume same carriage assembly - but not sure about the mule ?? thanks Share this post Link to post Share on other sites
Brockport Bill 1,940 #2 Posted June 11, 2021 as clarification -- i see the chart shows 78350 as distinguished from the 78355 - first is apparently a standard RD and the other is recycler RD - don't understand how that would change the assembly carriage adaptability to HC -- especially since it lists the H as a fit? Share this post Link to post Share on other sites
squonk 43,819 #3 Posted June 11, 2021 Should fit fine. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,482 #5 Posted June 11, 2021 Should work Mower DNA 1976 model 65-42MR01 replaced by - (Has the flat spindle belt idler pulley mounted on a triangular plate.) - (Has multi-link hardware at the gauge wheel support) 1977 model 75-42MR01 - Both use blades with 5/8" x 3/4" double-D center hole unless the spindles have been upgraded. (Has the flat spindle belt idler pulley mounted on a triangular plate) - (Has multi-link hardware at the gauge wheel support) ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- These all use blades with 3/4" center hole. 1977 model 75-42MR02 replaced by - (Has the flat spindle belt idler pulley mounted on a flat bar) (Has multi-link hardware at the gauge wheel support) 1978 model 85-42MR01 - (Has the flat spindle belt idler pulley mounted on a flat bar) (Has multi-link hardware at the gauge wheel support) 1979 model 95-42MR01 - No ipl available 1979 model 95-42MR02 - (Has no multi-link hardware at the gauge wheel support) 1980-1983 model 05-42MR01 1984 model 05-42MR02 - Last year for bearings with 3/4" ID 1985 model 05-42MR03 - First year for bearings with 17mm ID unless older spindles were updated. 1986-1988 model 05-42MR04 1989-1990 model 15-42RC01 1990-1992 model 15-42RC02 1993-2012 model 78350 Note - 17mm is .669" Garry Share this post Link to post Share on other sites
Brockport Bill 1,940 #6 Posted June 11, 2021 Garry -- you said should work -- on a 78355 on a HC ?????????? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,482 #7 Posted June 11, 2021 1 hour ago, Brockport Bill said: Garry -- you said should work -- on a 78355 on a HC ?????????? A 78350 is a replacement for the 15-42RC01. A 78355 is a 78350 with a 86001 recycler kit added. You can download the 1988 Attachment list here Garry 1 Share this post Link to post Share on other sites
Brockport Bill 1,940 #8 Posted June 11, 2021 Terrific -- thanks -- A+ help as always 1 Share this post Link to post Share on other sites
