Jonnyrocket132 38 #26 Posted June 9, 2021 okay that helps me a lot thank you Share this post Link to post Share on other sites
JCM 11,259 #27 Posted June 9, 2021 When checking your clean oil level after removing the dipstick carefully lay it on a clean paper towel but do not slide it or move it, that will make an imprint for you to get an approximate reading. @Jonnyrocket132 to 3 1 Share this post Link to post Share on other sites
Jonnyrocket132 38 #28 Posted June 9, 2021 that will solve that problem thank you 1 Share this post Link to post Share on other sites
JCM 11,259 #29 Posted June 9, 2021 Great tractor that 310. This was dropped off at my house, I interrupted it on the way to the dump, I just couldn't let that happen. Doesn't smoke or burn oil. Some before and after a clean-up and refurb pictures. 1 4 2 Share this post Link to post Share on other sites
tunahead72 2,635 #30 Posted June 9, 2021 14 hours ago, Jonnyrocket132 said: .. while I was mowing with my 310-8 the engine started to act like it was being overloaded when I was mowing grass that wasn't that tall ... 3 hours ago, Jonnyrocket132 said: at the time the engine was acting overloaded, I had the deck lowered low because my dad likes the grass cut really low. I don't know if that had anything to do with it or not That's quite possible. You may have to make two passes, at a slow ground speed and with the engine at full throttle. I typically mow in 2nd or 3rd gear low range in high grass with both my C-105 and 310-8. First pass might be with the deck raised to the transport position (not recommended long-term), then with the deck down but at the highest position. Try that and see if it helps. Share this post Link to post Share on other sites
Jonnyrocket132 38 #31 Posted June 9, 2021 why on earth would someone want to bring that to the dump? 2 Share this post Link to post Share on other sites
Handy Don 16,944 #32 Posted June 10, 2021 8 hours ago, Jonnyrocket132 said: why on earth would someone want to bring that to the dump? Bought a shiny new tin can Cub at the big box store? Likes sizzle but not steak? 1 Share this post Link to post Share on other sites
Jonnyrocket132 38 #33 Posted June 10, 2021 yeah it is a shame that these days all the manufacturers care about is looks and not the quality of the tractor Share this post Link to post Share on other sites
