Renrag   69 #1 Posted June 7, 2021 The craziest thing I got my horse out after about 2 weeks in shed and she grew fur and turned slimy green🤨, well at least the carb did. I thy using premium gas, but I believe some cheap ethenol gas was introduced to her. Now my question is does anyone have a 11h carb or is this 1982 carb worth trying to save, it already sucks air from throttle pin shaft or whatever it's called, not sure, but do the new carbs work on the older motors. What do you suggest.     Is it possible to find a good clutch for a b115 I believe it's a bp05 model. Thanks for any advise or help ty Share this post Link to post Share on other sites
8ntruck   8,482 #2 Posted June 7, 2021 (edited) The original carb is worth an attempt to rebuild - assuming it is a Kohler. Carb rebuild list are available for less than 20 dollars. Bronze bushings are available to bush the top throttle shaft bore to fix the air leak.  Many have here been down this road. I'm sure somebody will reply with more details soon.  Good luck, and have fun. Edited June 7, 2021 by 8ntruck Share this post Link to post Share on other sites
daveoman1966   3,881 #3 Posted June 7, 2021 5 hours ago, Renrag said:     Is it possible to find a good clutch for a b115 I believe it's a bp05 model. Thanks for any advise or help ty Are you asking about the PTO clutch for the B-115?   Share this post Link to post Share on other sites
lynnmor   8,384 #4 Posted June 7, 2021 8 hours ago, Renrag said:  I thy using premium gas, but I believe some cheap ethenol gas was introduced to her.  Premium gasoline might have even more ethanol in it, the price you pay is meaningless. If you want ethanol free gasoline, then you need to buy it from a pump that is labeled ethanol free. Share this post Link to post Share on other sites
Gregor   4,847 #5 Posted June 7, 2021 6 minutes ago, lynnmor said: then you need to buy it from a pump that is labeled ethanol free And I'm not sure I always believe those labels either. Share this post Link to post Share on other sites
peter lena   9,644 #6 Posted June 7, 2021 @Renragwhy not just regularly ad STA-BIL to your gas ? every time I top off my tank , I add the STA-BIL ,bottle neck measurement to my fuel , no issues at all . if I were you, I would also put a bottle of SEAFOAM IN THAT SYSTEM . just my own experience , pete 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) Â Â 11,921 #7 Posted June 7, 2021 12 hours ago, Renrag said: Is it possible to find a good clutch for a b115 I believe it's a bp05 model. Thanks for any advise or help ty You may find a good used one as the were used 1978 to late 80's. Try A-Z in the vendors. Part number 106565 replaced by 111321 Â New https://www.psep1.biz/arinet.asp#/s/TO//111321/1/ Â Garry Share this post Link to post Share on other sites
