AHS 1,675 #1 Posted June 6, 2021 I gave my father the 1970 wheel horse 12hp to my fathers 79 C111. So, what’s the ignition switch? The same as it is from Briggs to Kohler? It’s a huge upgrade as far as I’m concerned, the Briggs is tired, and still running, and it smokes some terribly bad! (I thought it was going to blow up 10 years ago!) so, what are the change from Briggs to Kohler? I’m all ears! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,259 #2 Posted June 7, 2021 What is the Spec number of the 12hp Kohler. Need to determine what ignition system it has. Garry Share this post Link to post Share on other sites
Stepney 2,357 #3 Posted June 7, 2021 If the Kohler had a magneto ignition, it should be the same switch.. charging system prevailing. If it's battery, you will need a battery ignition switch. Otherwise, very simple swap. I swapped a Kohler 14 in place of a 18HP B&S twin on a WorkHorse GT1848. A few simple wires and a little tweak to the belt cover. Share this post Link to post Share on other sites
953 nut 66,392 #4 Posted June 7, 2021 If the 1970 Kohler engine is original and unmolested it should have the solid state trigger ignition and if the Brigs has a mag ignition system there should be no need for a new switch. Post pictures of the ignition components of both to be sure. Share this post Link to post Share on other sites
AHS 1,675 #5 Posted June 7, 2021 The Kohler has a solid stater ignition, it has a 12v coil and a solenoid on the tractor. I’m sorry, this should be in electrical, moderators. 1 Share this post Link to post Share on other sites
Gregor 4,848 #6 Posted June 7, 2021 It's anyones guess what was done to either motor over the years. Do both motors have an external coil? Pics of both would help. Share this post Link to post Share on other sites
953 nut 66,392 #7 Posted June 7, 2021 1 hour ago, AHS said: Kohler has a solid stater ignition, it has a 12v coil Pick one from this picture. 3 Share this post Link to post Share on other sites
AHS 1,675 #8 Posted June 8, 2021 Sorry bout that! I added the solenoid because it had solenoid/key switch! Just a regular old Kohler! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,259 #9 Posted June 10, 2021 The C-111 uses a battery type of ignition switch to control a kill relay to control the B&S magneto ignition. The Kohler with round coil is battery ignition so the C-111 ignition switch will work. You need to eliminate the kill relay and extend the ignition wire to the coil (+) terminal on the round coil. This is how the Kohler should be wired to the coil Garry Share this post Link to post Share on other sites
