barns1 57 #1 Posted June 3, 2021 Hi All, Just picked up another Horse, C160 Auto and I need to buy a good quality carb for the 16hp Kohler. I've searched and searched but I can't remember the name of the supplier I've used before. Any suggestions? Thanks 1 Share this post Link to post Share on other sites
ebinmaine 73,658 #2 Posted June 4, 2021 A to Z Tractor in PA 1 1 Share this post Link to post Share on other sites
ebinmaine 73,658 #3 Posted June 4, 2021 But first..... Why do you need another carb? Yours rebuildable? 1 Share this post Link to post Share on other sites
barns1 57 #4 Posted June 4, 2021 (edited) It's the wrong carb, looks like it might have come off a Power King or similar. The C160 is a fixer upper I came across, just a few things missing, trying to make it right. Thanks by the way for A to Z. Edited June 4, 2021 by barns1 1 Share this post Link to post Share on other sites
seuadr 489 #5 Posted June 4, 2021 isavetractors.com has good quality carbs too. 2 Share this post Link to post Share on other sites
barns1 57 #6 Posted June 4, 2021 Thank you for that info, in fact I just ordered from them. Thanks again. Share this post Link to post Share on other sites
lynnmor 7,949 #7 Posted June 4, 2021 8 minutes ago, barns1 said: Thank you for that info, in fact I just ordered from them. Thanks again. I thought you didn't want Chinese? 1 Share this post Link to post Share on other sites
seuadr 489 #8 Posted June 4, 2021 10 minutes ago, lynnmor said: I thought you didn't want Chinese? A to Z sells used stuff - he should be getting a genuine carb. 1 Share this post Link to post Share on other sites
lynnmor 7,949 #9 Posted June 4, 2021 1 minute ago, seuadr said: A to Z sells used stuff - he should be getting a genuine carb. I thought he ordered from the other guy. A used carb is probably the only way to stay away from Chinese. 4 Share this post Link to post Share on other sites
seuadr 489 #10 Posted June 4, 2021 1 minute ago, lynnmor said: I thought he ordered from the other guy. A used carb is probably the only way to stay away from Chinese. i guess i am assuming he ordered from A to Z i don't know where isavetractor's carbs come from, but they are higher quality than the amazon stuff - brass floats and seats, etc. Share this post Link to post Share on other sites
barns1 57 #11 Posted June 4, 2021 (edited) I searched and checked around and it seems new carbs are discontinued. A to Z didn't have a carb for the 16hp Kohler, thought maybe I could get a used one and rebuild it. So I went with I save tractors as they do come with brass floats, etc. Hopefully it will work out, at least I will have something to get the tractor running correctly. Edited June 4, 2021 by barns1 Share this post Link to post Share on other sites
pacer 3,177 #12 Posted June 4, 2021 Carbs have seemingly entered into the love/hate groupings of -- what oil/what paint/filter, etc. New Import or rebuild?? My personal experience is - I'll pay the under $20 for an import. I've bought maybe 6-8 of them and aside from having to change the choke shaft, I had one that I couldnt get the float to seal off. On another it didnt have the ... anti-slosh gasket? and fuel would 'slosh' into the intake and burp out a big puff of black smoke and stumble -- I added the 'anti slosh' gasket and stopped that. As for rebuild I never had much luck with that.... the brass piece that the main adjuster screws into is almost impossible to get out, and on the couple that I did get out it was clogged. And all too often after a cleaning, I still have a crappy running engine. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,339 #13 Posted June 4, 2021 The last Chinese carb l got l went to adjust the float and the part were the pin goes thru broke off from the plastic float! Junk 1 Share this post Link to post Share on other sites
squonk 44,133 #14 Posted June 4, 2021 1 hour ago, pacer said: Carbs have seemingly entered into the love/hate groupings of -- what oil/what paint/filter, etc. New Import or rebuild?? My personal experience is - I'll pay the under $20 for an import. I've bought maybe 6-8 of them and aside from having to change the choke shaft, I had one that I couldnt get the float to seal off. On another it didnt have the ... anti-slosh gasket? and fuel would 'slosh' into the intake and burp out a big puff of black smoke and stumble -- I added the 'anti slosh' gasket and stopped that. As for rebuild I never had much luck with that.... the brass piece that the main adjuster screws into is almost impossible to get out, and on the couple that I did get out it was clogged. And all too often after a cleaning, I still have a crappy running engine. I forget the socket size but buy a cheapie and ground down the sides to make the walls thinner. 1 Share this post Link to post Share on other sites
pacer 3,177 #15 Posted June 4, 2021 2 hours ago, squonk said: ground down the sides to make the walls thinner. That sounds like for getting the needle seat out and yes I did the same thing -- took an old deep 3/8 socket 1/4 drive and ground the sides till it would get that little booger out!! The part I was referring too takes a flat blade screwdriver and it has about 4-5 rows of thread exposed and they get corroded along with it just being plain STUCK! Share this post Link to post Share on other sites
squonk 44,133 #16 Posted June 4, 2021 Oh ok Now I know what you talking about. Takes a good non worn screwdriver to get that out. And also a prayer Share this post Link to post Share on other sites
pacer 3,177 #17 Posted June 4, 2021 Since this part of the carb is/was being discussed, it just might be that some of you arent aware its in there. When you put the bowl on using that 9/16" nut to snug the bowl up, the part that that bolt screws into, sort of tube like has a brass piece inside that the metering screw goes thru and its threaded in. It can, and will get corrosion/gunk in it and while a good blast of carb cleaner will usually clear it out, not always and needs to be screwed/backed out to get it clean --- and its usually stuck!! Share this post Link to post Share on other sites
biged77 113 #18 Posted June 5, 2021 The mainland Chinese carbs are in the $10-$20 range. The Taiwan carbs from Isavetractors are in the $60 range. Although I have not used either one, preferring to rebuild the original carbs, Taiwan products are typically higher quality in my experience. Share this post Link to post Share on other sites
953 nut 61,024 #19 Posted June 5, 2021 Biggest problem I've found with the Chinese knock-off carbs it that they are advertised as 10-12-14-16 HP. they are jetted for the larger displacement engines and generally will work OK on the 14-16 HP engine but can't be adjusted to work well on the 10-12. One size doesn't fit all. I pulled the jets and brass float out of an old Carter and made it work fine in a 12. Share this post Link to post Share on other sites
wallfish 18,441 #20 Posted June 6, 2021 Had a damaged carb on a K532 20hp. No choice but a new carb as someone cranked that bowl bolt so tight it cracked the cast. Bought a new one from Isavetractors and it worked out great. So far so good. I've had some flooding issues with a couple of the chinese carbs for Kohlers but haven't had a problem with Teccy snow blower carbs. Share this post Link to post Share on other sites
