DavidB
244-H with E140 engine - carb parts needed
DavidB
Does anyone know whose carbs ONAN used on this engine? I need a few small parts and I thought I could try the original manufacturer to see if I could find a fit. Using ONAN part numbers, a $0.02 plastic clip is going for $30+ and a small, 1" linkage rod is about the same. And replacement air screws are simply not available. I'll McGyver something if I can 't find parts, but the proper bits would be preferable.
Thanks.
