wh1075 6 #1 Posted June 1, 2021 I am new to red square. I realize this information may already be posted but I was unable to find it. I have an RJ-58. My Great Uncle purchased it new and I acquired it from him in 2001. Sometime before the tractor came to me the pulleys on the engine and transmission were changed to different sizes. I imagine this was to change ground speed. I am not planning a restoration but would like to put the original pulley sizes back on the tractor. Unfortunately my Great Uncle has passed away and I am unable to find the original pulleys in the inventory that I acquired from him. I am not looking for NOS but rather dimensions of the correct pulley that I can source elsewhere. I believe the original part number is #1611. Thanks for any help that you can give. Share this post Link to post Share on other sites
WHX?? 56,165 #2 Posted June 1, 2021 (edited) Here are some files on your RJ if that helps nail down part numbers. 1611 is correct for the transmission, 1608 for the motor. I or other members can get you the actual dimensions if needed. Got any of your RJ? Tractor 1958-1959 RJ-58 & RJ-59 D&A OM IPL SN.pdf - 1955-1964 - RedSquare Wheel Horse Forum Edited June 1, 2021 by WHX24 Share this post Link to post Share on other sites
wh1075 6 #4 Posted June 1, 2021 Thanks for the info. I will take a look at the information when I get a chance. I will try to post some pictures later when I have some more time 1 Share this post Link to post Share on other sites
