David Callender 0 #1 Posted May 31, 2021 I'm looking at a C-141 for mowing Soccer field pulling two extra motorized decks, is this tractor capable of this or not please help? Share this post Link to post Share on other sites
Gregor 4,847 #2 Posted May 31, 2021 You don't say the size of your decks, but I would say yes, if it still has the 14 HP Kohler 1 Share this post Link to post Share on other sites
cschannuth 3,819 #3 Posted May 31, 2021 (edited) The deck on the 141 will take much more HP than what it takes to tow the two self powered pull behinds. My little 6.5 HP pulls the 500 lb lawn roller like it’s not even there so if the 141 can handle it’s own deck, towing the other mowers should tax it very little. Edited May 31, 2021 by cschannuth 4 Share this post Link to post Share on other sites
ebinmaine 77,309 #4 Posted May 31, 2021 1 hour ago, cschannuth said: if the 141 can handle it’s own deck, towing the other mowers should tax it very little That's about what I was thinking too. When I was a kid back in the 70s my father made a gang mower from an 8 HP ariens towing (I think) 5 20" wide push mowers all bolted together with angle iron. You should be fine. 2 Share this post Link to post Share on other sites
c-series don 11,360 #5 Posted May 31, 2021 Since it’s a flat field it will be fine you’re not towing up and down a hillside. Is it an 8- speed or an automatic? I was just curious. Do you have any pictures? 1 Share this post Link to post Share on other sites
Achto 30,967 #6 Posted June 1, 2021 Like stated above, I think a C-141 would have no problem performing the task that you described. Share this post Link to post Share on other sites
