matzopie 0 #1 Posted May 31, 2021 CAN SOMEONE TELL ME THE DIFFERENCE BETWEEN THE FOLLOWING MODEL NUMBERS? 05-37SC01 05-37SC02 05-37SCO3. THE DECK I HAVE NOW HAS NO ID NUMBER ON IT. I UNDERSTAND THERE ARE TWO BELT NUMBERS THAT COULD BE USED ON THESE DECKS. 111178 OR 110265. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,754 #2 Posted May 31, 2021 05-37SC01 uses a 6-sided belt and all the pulleys are V-pulleys. 05-37SC02 and 03 use a 4-sided belt and the wide back of the belt runs over flat idlers. Two on the deck and one on the front idler assembly. All could be changed to the other by changing the appropriate idlers so unless you know the deck history this does not identify the deck model number. Click on the picture in each link to see the belts used. Garry Share this post Link to post Share on other sites
dcrage 631 #3 Posted May 31, 2021 Gary Both of the deck idlers are flat for the standard 4 sided belt setup. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,754 #4 Posted May 31, 2021 40 minutes ago, dcrage said: Gary Both of the deck idlers are flat for the standard 4 sided belt setup. Thanks. I should have realized that. Garry Share this post Link to post Share on other sites
