ScottyMac 1 #1 Posted May 30, 2021 I recently bought my mother a beautiful little 8-25 for her to mow her lawn (it looks nearly new) rather than let her dump $1500 on a new piece of junk. It runs and performs perfectly. However, the clutch seems to be a little touchy. When you let the clutch out, no matter how slowly, it lurches forward abruptly. Is there an adjustment to soften the transmission engagement? None of my other WH - I have a couple 312-8's- are jumpy like this. Share this post Link to post Share on other sites
stevasaurus 23,620 #2 Posted May 30, 2021 The thing is, it is still a belt driven riding lawn mower. Check the drive pulleys for any rust. Clean pulleys so they shine and put some mineral spirits on the pulleys. That should help a ton. If it still does it..."maybe" wipe the belt with mineral spirits also...do not soak the belt...just wipe. Check tension spring also. Share this post Link to post Share on other sites
peter lena 9,779 #3 Posted May 30, 2021 @SCOTTYMAC, take the time to LUBRICATE THE RELATED LINKAGE , I also firmed up every end connection point with extra washers and lube , when the rust runs out , you are on the right track. maybe that clutch spring is too soft , also check out your related pulleys , sloppy or noisy bearings will also do it , pete Share this post Link to post Share on other sites
