Gregor 4,847 #1 Posted May 25, 2021 I don't know if this really falls under "Other Brands" or not, but I thought I would ask anyway. Lawnboys have very finikiy, plastic carburetors. Do you think ut would be OK to soak one of them in Berrymans, and then run through a sonic cleaner? Share this post Link to post Share on other sites
WHX?? 52,889 #2 Posted May 25, 2021 I would be prone to say yes. Might want to be careful about what fluid is in the ultra tho. Share this post Link to post Share on other sites
Gregor 4,847 #3 Posted May 25, 2021 26 minutes ago, WHX24 said: I would be prone to say yes. Might want to be careful about what fluid is in the ultra tho. I just use Simple Green and water. Share this post Link to post Share on other sites
WHX?? 52,889 #4 Posted May 26, 2021 (edited) You'll be fine then. Simple green or purple power should do a nice job. Not sure how it does on varnish but dirt and grime Edited May 26, 2021 by WHX24 Share this post Link to post Share on other sites
Stepney 2,354 #5 Posted May 26, 2021 (edited) Are we talking an old F series plastic carb?? Or a Duraforce? Either way. The jets are all removable on both. And the usual 'finicky carb' tends to actually be intake or crank seal leaks. Very simple carb. As for the question at hand.. I'd remove and soak the parts, but not the whole carb.. I've watched parts simply vanish in my carb cleaner before. Edited May 26, 2021 by Stepney 1 Share this post Link to post Share on other sites
Gregor 4,847 #6 Posted May 26, 2021 7 hours ago, Stepney said: Are we talking an old F series plastic carb?? Or a Duraforce? I have both, but the particular carb I have in mind, is from a 6.5 Dura Force. Share this post Link to post Share on other sites
