tarcoleo 119 #1 Posted May 23, 2021 Has anyone replaced crank oil seals on this Honda engine and it's Chinese clones without disassembling the engine itself? Can an old seal be removed and a new seal pressed or tapped in for replacement? Thanks in advance, -Tom Share this post Link to post Share on other sites
Maxwell-8 4,367 #2 Posted May 24, 2021 Normally yes. Share this post Link to post Share on other sites
tarcoleo 119 #3 Posted May 27, 2021 Hey y'all, this post started with the idea that an oil leak problem I had was coming from a failed crank shaft oil seal. Wrong, the leak was found this morning; if was from the obscure second filler/dipstick port on the crank case. Once tightened, problem solved. Thanks everybody, sorry if I wasted anyone's time. Moral; "simple answers are better than complicated ones". Share this post Link to post Share on other sites
