redone 45 #1 Posted May 20, 2021 Guys. I am a little rusty at this timing of balance gears. I do have this special tool that sites on the edge of the block and holds the gears in place, but. do i set the at the timing markes on crank shaft and continue installing crank into the block? My block that i am rebuilding already had those gears in the block before machining and doing the valve work. i do not want to ruin this motor. getting the balance gears out of wack Thanks for your help Bill Share this post Link to post Share on other sites
Shynon 7,520 #2 Posted May 21, 2021 I personally would remove the balance gears, I do it on every motor I rebuild. They are just a hole in the block waiting to happen. 1 1 Share this post Link to post Share on other sites
kpinnc 16,627 #3 Posted May 21, 2021 I remember years ago, balance gears being referred to as "grenade gears"... Not to mention, unless your tractor has a suspension (shaker) mount you won't know the difference without them. Especially true for a K241. They are smooth amd quiet even without them. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #4 Posted May 21, 2021 Take out and thro them as far as you can ! l concur on above ! You dont notice alot with them takin out. I just leave the pins they go on in place. Share this post Link to post Share on other sites
rmaynard 16,771 #5 Posted May 21, 2021 I did not know that any K-241's had balancing gears. Share this post Link to post Share on other sites
squonk 45,083 #6 Posted May 21, 2021 2 minutes ago, rmaynard said: I did not know that any K-241's had balancing gears. From Brian Miller's site: " Only thirteen K241 engines came from Kohler with balance gears installed. These engines have the specification numbers: 46578, 46634; (Allis Chalmers); 46590 (Yazoo); 46593, 46608, 46633 (John Deere); 46664, 46718, 46764, 46803 (Simplicity); 46809, 46810 (Grainger); and 46838 (Ingersoll Rand). " 1 Share this post Link to post Share on other sites
rmaynard 16,771 #7 Posted May 21, 2021 7 minutes ago, squonk said: From Brian Miller's site: " Only thirteen K241 engines came from Kohler with balance gears installed. These engines have the specification numbers: 46578, 46634; (Allis Chalmers); 46590 (Yazoo); 46593, 46608, 46633 (John Deere); 46664, 46718, 46764, 46803 (Simplicity); 46809, 46810 (Grainger); and 46838 (Ingersoll Rand). " Thanks for that info Mike. Maybe I should have said "I did not know that any Wheel Horse K-241's had balancing gears". 1 Share this post Link to post Share on other sites
oliver2-44 11,137 #8 Posted May 21, 2021 Another vote to take them out. I have a K341 block destroyed by balance gears needle bearings failing Share this post Link to post Share on other sites
WHX?? 53,762 #9 Posted May 21, 2021 Fourth on leaving them out unless your a purist. Any chance your spec no's match what Squonky posted? Share this post Link to post Share on other sites
squonk 45,083 #10 Posted May 21, 2021 Leave them out! Share this post Link to post Share on other sites
