motay 0 #1 Posted May 16, 2021 I have a C100-8 with a 42 inch mowing deck. I am 6 foot and it's a tight fit for me when setting on the tractor. Can I move the seat back without getting in trouble with the weight shift to the rear? What is the best way to move the seat? Drill new holes for the existing brackets? Modify a sliding bracket from another brand? Share this post Link to post Share on other sites
ebinmaine 72,525 #2 Posted May 16, 2021 Do you have the tilt back seat pan? If so you NEED to make SURE the latch is fully contacting. I'm 6'1"+ and 2@#$ ALOT of pounds so I moved the seat back (( 2" ??)) on my 74 C160. I used 1.5" square multi hole steel. It's a bit of a distance shot. You can see what I did here. Share this post Link to post Share on other sites
stevasaurus 23,275 #3 Posted May 16, 2021 One of the things that I have found...going up is as good as moving back. I'm 6' 1" also, if I put a 2x4 under the seat and raise it 1 1/2" to 3 1/2" depending on how I turn the 2x4 and the go back 1 or 2 inches it works for me. Up and back is the answer. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,461 #4 Posted May 16, 2021 The clutch pedal can also be adjusted. It does not affect the clutch action - just the pedal position for operator comfort. Garry Share this post Link to post Share on other sites
tunahead72 2,543 #5 Posted May 16, 2021 2 minutes ago, gwest_ca said: The clutch pedal can also be adjusted. It does affect the clutch action - just the pedal position for operator comfort... Did you mean "does NOT affect the clutch action"? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,461 #6 Posted May 16, 2021 5 minutes ago, tunahead72 said: Did you mean "does NOT affect the clutch action"? Yes - body won't keep up with my mind. Thanks 2 Share this post Link to post Share on other sites
oliver2-44 10,698 #7 Posted May 17, 2021 You can put some 2x2 steel tubing on each side under the fender pan to raise the seat and fender. That way your ready to put larger diameter tires on it if you want too. 1 Share this post Link to post Share on other sites
Maxwell-8 4,367 #8 Posted May 17, 2021 13 hours ago, ebinmaine said: Where can i get one of those fancy stickers! 1 Share this post Link to post Share on other sites
ebinmaine 72,525 #9 Posted May 17, 2021 15 minutes ago, Maxwell-8 said: Where can i get one of those fancy stickers! I believe I got that from Terry the vinyl guy 1 Share this post Link to post Share on other sites
