Jonnyrocket132 38 #1 Posted May 14, 2021 (edited) Hi, I just picked up a wheel horse 417-8 for free a week ago and it ran good everything worked as it was suppose to but yesterday I went to put a brand new battery into it and as soon as I hooked it up it killed the battery and I treid my jumper pack just to see if I got a bad battery and it killed that to any ideas on what might have caused that? Edited May 14, 2021 by Jonnyrocket132 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,068 #2 Posted May 14, 2021 Welcome to the forum. Do you have the tractor model and serial number? Do you have a row of idiot lights on the dash? No - 1985, Yes - 1986 Needed to get the correct wiring diagram. Garry Share this post Link to post Share on other sites
Jonnyrocket132 38 #3 Posted May 14, 2021 I have the model number of the engine if that helps? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,068 #4 Posted May 14, 2021 Not necessarily for a no-start problem but will reveal other important features about your tractor. The tractor data decal may be in front of the seat or on the left side of the seat on the rear fender pan. When you post the engine numbers include the serial number. Garry 1 Share this post Link to post Share on other sites
Jonnyrocket132 38 #5 Posted May 14, 2021 (edited) oh that one okay it says a 1984 Edited May 14, 2021 by Jonnyrocket132 Share this post Link to post Share on other sites
Jonnyrocket132 38 #6 Posted May 14, 2021 (edited) model number for the the engine is KT17Qs spec. number is 24363 serial number is 1534312866 and the wheel horse is a 417-8 and the one that says the model number for the tractor is to faded for me to tell what it says Edited May 14, 2021 by Jonnyrocket132 Share this post Link to post Share on other sites
johnnymag3 2,643 #7 Posted May 14, 2021 That's one heck of a draw if it killed a new battery immediately !! Share this post Link to post Share on other sites
Jonnyrocket132 38 #8 Posted May 14, 2021 (edited) yeah I didn't even have to put the key in it to do that and it did the exact same thing to my fully charged jumper pack as well Edited May 14, 2021 by Jonnyrocket132 Share this post Link to post Share on other sites
Jonnyrocket132 38 #9 Posted May 14, 2021 normally I am able to figure out these types of issues but this one has me scratching my head because I have looked through all of the fuses and the safeties but it is still doing it Share this post Link to post Share on other sites
Jonnyrocket132 38 #10 Posted May 14, 2021 25 minutes ago, gwest_ca said: Welcome to the forum. Do you have the tractor model and serial number? Do you have a row of idiot lights on the dash? No - 1985, Yes - 1986 Needed to get the correct wiring diagram. Garry yes I do but I don't think they work Share this post Link to post Share on other sites
SPINJIM 1,996 #11 Posted May 14, 2021 Did you disconnect the battery before connecting the jumper pack? Could be dead short in the new battery. Obvious question, positive & negative correctly connected? Try putting your old battery back in temporarily, and see what happens. Jim Share this post Link to post Share on other sites
Jonnyrocket132 38 #12 Posted May 14, 2021 (edited) the battery is hooked up correctly. I tried the old battery and it finished of that old weak battery as well. I had the battery disconnected when I tried the jumper pack Edited May 14, 2021 by Jonnyrocket132 1 Share this post Link to post Share on other sites
Jonnyrocket132 38 #13 Posted May 14, 2021 here are some photos 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,068 #14 Posted May 14, 2021 Get the battery charged up with the negative cable disconnected from the battery. Connect a voltmeter between the negative battery cable and the negative battery post. If a short exists it will give you a voltage reading. Hooked up this way it will not create a heavy discharge on the battery. Disconnect different items until the short is eliminated. There is a short battery cable between the tractor frame and the engine. If it fails the starter won't work and perhaps the battery is not discharged. Your tractor is most likely a 1986 model 417-A Twin Automatic model 31-17KE02 with it's original engine. Kohler made your engine in 1985. 1 Share this post Link to post Share on other sites
Jonnyrocket132 38 #15 Posted May 14, 2021 (edited) this wheel horse is a 417-8 with electric mower deck lift 1984 Edited May 14, 2021 by Jonnyrocket132 Share this post Link to post Share on other sites
Jonnyrocket132 38 #16 Posted May 14, 2021 update, I checked the battery terminals and notice that the + terminal was crumbling on the starter relay so I replaced both battery terminals and tried it and it still drained the battery but not as fast as before Share this post Link to post Share on other sites
Bill D 2,678 #17 Posted May 14, 2021 Definitely a 1986 model due the louvers punched into the hood and the serial number of the engine. Start looking for melted wiring. You have a direct short somewhere. Bill Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,068 #18 Posted May 14, 2021 Connect a voltmeter or test light to the negative battery post. Take the other lead and drag it across the top of the battery from the positive post to the negative. If you have any voltage there dirt on the battery is causing a short between the battery posts 24-7. Remove battery from tractor and wash it up. Be careful as there is sulfuric acid on the surface so watch your clothes and tools for corrosion. Garry 1 Share this post Link to post Share on other sites
Jonnyrocket132 38 #19 Posted May 15, 2021 update I got it to run but the wiring was done by someone who obviously didn't know what they were doing so I had to rewire the whole thing 6 Share this post Link to post Share on other sites
Jonnyrocket132 38 #20 Posted May 15, 2021 thanks for the help 1 Share this post Link to post Share on other sites
Jonnyrocket132 38 #21 Posted May 16, 2021 (edited) I have another question, the carburetor is the original one and it is on its last legs and I ordered one but the choke cable wouldn't fit onto it. I have looked all over and found a couple but the choke cable wouldn't fit and I just can't seem to find one that works for this poor old wheelhouse 417-8, does anyone know where I can find the right carburetor for it? Edited May 16, 2021 by Jonnyrocket132 Share this post Link to post Share on other sites
oliver2-44 11,327 #22 Posted May 16, 2021 Why are you saying you carb is on it’s last leg? They are rebuildable and worn choke shafts can be bushed. If your looking at aftermarket Chinese carbs many of us have no had good luck with them! Share this post Link to post Share on other sites
Jonnyrocket132 38 #23 Posted May 17, 2021 (edited) it leaks in several different places and a lot of the fuel mixture screws are rusted in to where you can't adjust the idle or the air fuel mixture and it wasn't treated well by the previous owners Edited May 17, 2021 by Jonnyrocket132 Share this post Link to post Share on other sites
Jonnyrocket132 38 #24 Posted May 17, 2021 yeah maybe your right. I will try and repair the cracks with some JB weld and install a new carb rebuild kit that I have and see if it will work Share this post Link to post Share on other sites
richmondred01 2,349 #25 Posted May 22, 2021 If your wiring harness is messed up PM me. I have a complete 417-8 wiring harness. Share this post Link to post Share on other sites
