theoldwizard2 2 #1 Posted May 8, 2021 I'm old. My eye sight is not as good as it used to be. I can not see TDC on the points rod on my K241 to adjust the new ones. You can't use the screwdriver trick because the spark plug is not directly over the piston. Is there and easy to view TDC external indicator ? Share this post Link to post Share on other sites
stevasaurus 23,534 #2 Posted May 8, 2021 This is the best way to set the points. This says it all. 2 Share this post Link to post Share on other sites
squonk 45,083 #3 Posted May 8, 2021 This works well. As long as your hearing is better than your eyesight! TDC Whistle https://www.summitracing.com/parts/mrg-8016mrg 1 Share this post Link to post Share on other sites
Handy Don 15,641 #4 Posted May 8, 2021 2 hours ago, squonk said: This works well. As long as your hearing is better than your eyesight! TDC Whistle That is one clever idea. Works even with compression release! Share this post Link to post Share on other sites
theoldwizard2 2 #5 Posted May 10, 2021 On 5/8/2021 at 12:59 PM, stevasaurus said: This is the best way to set the points. This says it all. I watched that video. Where EXACTLY is that sight hole ? Share this post Link to post Share on other sites
squonk 45,083 #6 Posted May 10, 2021 That hole is on your flywheel shroud towards the front. If your engine is older there is a plug covering a hole in the bearing plate to view the timing marks. It's on the backside of the engine. If you have a starter generator, it will be hard to see. Share this post Link to post Share on other sites
