Horse_rebuilder 5 #1 Posted May 4, 2021 Now I know how they introduced the magnums in 87’ and the k241 correlates to the m10, k301 to 12 and so on, however are the magnums the exact same as there older counter parts? Share this post Link to post Share on other sites
Maxwell-8 4,370 #2 Posted May 4, 2021 4 minutes ago, Horse_rebuilder said: Now I know how they introduced the magnums in 87’ and the k241 correlates to the m10, k301 to 12 and so on, however are the magnums the exact same as there older counter parts? For sure the block, Main differences is metal vs plastic fan shroud. Share this post Link to post Share on other sites
Horse_rebuilder 5 #3 Posted May 4, 2021 Just now, Maxwell-8 said: For sure the block, Main differences is metal vs plastic fan shroud. So would it be true to say the internals are the same like bore, stroke, etc.? Share this post Link to post Share on other sites
Maxwell-8 4,370 #4 Posted May 4, 2021 As far as i know yes, but i am not certain. This may help. https://www.engine-specs.net/kohler Share this post Link to post Share on other sites
pfrederi 19,894 #5 Posted May 4, 2021 Internal are the same big difference is ignition. magnum use magnetos 2 Share this post Link to post Share on other sites
Horse_rebuilder 5 #6 Posted May 4, 2021 4 minutes ago, pfrederi said: Internal are the same big difference is ignition. magnum use magnetos Alright thankyou to all of you for your help Share this post Link to post Share on other sites
roadapples 6,987 #7 Posted May 4, 2021 Yup, no points to fool with on a magnum... Share this post Link to post Share on other sites
kpinnc 17,159 #8 Posted May 4, 2021 (edited) The blocks did not change much between K and M models. Many 10 and 12hp between the two both have "K301" cast above the PTO bearing. As has already been stated, ignition type, and flywheel bearing plate are where they differ. Points cover and starter mounting is different too. Cranks, pistons, rods, cams and valves are the same from K241/ M10 and so on. Edited May 4, 2021 by kpinnc 1 1 Share this post Link to post Share on other sites
Lee1977 7,554 #9 Posted May 4, 2021 The crank shaft is different in the Magnums. The K-series will run with out balance gears, don't think the Magnum will, they have either 2 or 3 balance gears. Share this post Link to post Share on other sites
pfrederi 19,894 #10 Posted May 4, 2021 2 hours ago, Lee1977 said: The crank shaft is different in the Magnums. The K-series will run with out balance gears, don't think the Magnum will, they have either 2 or 3 balance gears. Are you sure about this?? i do not know of any 3 balance gear units. Some older k did not have balance gears but most big blocks did. A quick look at K341 and Magnum 16 shows same crankshaft part numbers for various specs Share this post Link to post Share on other sites
Lee1977 7,554 #11 Posted May 5, 2021 1 hour ago, pfrederi said: Are you sure about this?? i do not know of any 3 balance gear units. Some older k did not have balance gears but most big blocks did. A quick look at K341 and Magnum 16 shows same crankshaft part numbers for various specs Your right. It's just some models, may be for Sears junk. I saw the pictures years ago, some models use the same crank shaft M12 thru M16. That is where I saw the three balance gears on the M16. Share this post Link to post Share on other sites
