mort 24 #1 Posted May 2, 2021 What do I need to look for when buying rims? If I can find some rims with tires on them what is the lug nut spacing I need? Are there any brand tractors that will work for sure like Simplicity for rims? I know the 23 X 10.5 -12 will work on the 520HC but are there any issues for a 518H? Do the 10.5 use the same 7" rim? Share this post Link to post Share on other sites
kpinnc 14,636 #2 Posted May 2, 2021 (edited) 1 hour ago, mort said: I know the 23 X 10.5 -12 will work on the 520HC but are there any issues for a 518H? Do the 10.5 use the same 7" rim? A 10.5 turf tire will fit the 7.5 inch rim just fine. I have a couple like that. An 10.5 ag tire won't, simply due to there being less flex across the cleats. You can get it on there, but the beads won't seat right. Go with turfs and you should be fine. Edited May 2, 2021 by kpinnc Share this post Link to post Share on other sites
ACman 7,655 #3 Posted May 2, 2021 (edited) The 520’s use a 8.5’ rim and pretty much all garden tractors use the same Ford/dodge bolt pattern. If you find a set for a decent price and the offset isn’t right you can buy a set of spacers of fleabay or the jungle site pretty cheap. Wheel Horse rims don’t have much of a inside offset 1.250” . Edited May 2, 2021 by ACman Share this post Link to post Share on other sites
mort 24 #4 Posted May 3, 2021 I think the 310-8 have a 7" rim not a 7.5" rim. What about the 518H? Is it 7" or 8.5"? Thanks, Mort Share this post Link to post Share on other sites
Tuneup 1,452 #5 Posted May 3, 2021 My 516H has a 7.5" wheel - guessing that the 518H is the same. The 520H is 8.5". 23x10.5x12 Deestone Ags on the 520 but they tend to run on the narrow side. Share this post Link to post Share on other sites
mort 24 #6 Posted May 3, 2021 I thought the 520 H was 23 X 9.50-12 and the 520 HC was 23 X 10.5 -12 That is what some of my books are showing. Thanks, Mort Share this post Link to post Share on other sites
Tuneup 1,452 #7 Posted May 4, 2021 Hi Mort - yes, it was disconcerting. Was hoping I had 10s but the 520H measured 8.5. Share this post Link to post Share on other sites
