Horse_rebuilder 5 #1 Posted May 2, 2021 So I just got the horse and it came with a Koehler m12, however it has a 312-8 hood and frame it seems, now I’m curious if they only started putting magnums on instead of the k series when toro bought it or something else, the real question is when did they start using the magnum engines, like what year 1 Share this post Link to post Share on other sites
squonk 46,731 #2 Posted May 2, 2021 If your going to ask why the engine hangs over the frame on the PTO side, there are 2 bolts coming up from the bottom on that side that thread into the pan. 1 Share this post Link to post Share on other sites
Horse_rebuilder 5 #3 Posted May 2, 2021 8 minutes ago, squonk said: If your going to ask why the engine hangs over the frame on the PTO side, there are 2 bolts coming up from the bottom on that side that thread into the pan. Sorry, I might have Fraser the question wrong, what year of models did wheelhouse start using the Koehler magnum engines instead of the Kohler k series Share this post Link to post Share on other sites
Horse_rebuilder 5 #5 Posted May 2, 2021 1 minute ago, Lee1977 said: 1987 Alright thankyou 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #6 Posted May 2, 2021 I have a 1986 310-8 with the magnum . 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #7 Posted May 2, 2021 To my knowing 1985 was the last year off pre-toro WH's, fur sure on trannys, probably engine too. i guess Share this post Link to post Share on other sites
tunahead72 2,633 #8 Posted May 2, 2021 @Horse_rebuilder As near as I can tell, the '86 308-8 came with a Magnum, the others started in '87. Check this out: Model# List - Model List 1984-Present - RedSquare Wheel Horse Forum 2 Share this post Link to post Share on other sites
