WheelhorseBob 1,550 #1 Posted April 29, 2021 Are the early C series hoods the same as the later? I’m restoring a 121 and found a 120 hood. Same? I know the tower is different. Share this post Link to post Share on other sites
rmaynard 16,860 #2 Posted April 29, 2021 Just check the parts manuals for each. Share this post Link to post Share on other sites
6wheeler 675 #3 Posted April 30, 2021 (edited) I believe up until the black hoods the were. I know the C-160 and C- 120 are. As long as the latch works. I think it does. I think the headlight lense may be a bit different. Than what your 121 has. You could switch the lense if it is an issue. But? It should be very similar. Edited April 30, 2021 by 6wheeler 1 Share this post Link to post Share on other sites
ebinmaine 77,309 #4 Posted April 30, 2021 I've had a 73 auto here that had a C121 hood. Should work fine. 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #5 Posted April 30, 2021 37 minutes ago, ebinmaine said: I've had a 73 auto here that had a C121 hood. Should work fine. Thank you Eric, much appreciated! 1 Share this post Link to post Share on other sites
RJR49 159 #6 Posted May 2, 2021 I have a " Frankenhorse" It's a C-160 with a C-101 hood, and a C-112 fender / seat-pan. As long as you're not swapping long frame / short frame components you should be OK 1 Share this post Link to post Share on other sites
