Jack marcham 51 #1 Posted April 28, 2021 could anyone tell me which belt i need for my wheel horse a81 with a 36 inch cutting deck many thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,996 #2 Posted April 28, 2021 36" rear discharge? There were 12 different models of electric start and recoil start A-81's. Half likely use the same decks. There are 3 model numbers for the 36" rear discharge deck and we just have info on two of them and those 2 use different belts. That does not happen often so something changed. Any deck model number still readable? How about the tractor model number? There is no side discharge 36" deck listed. Just 32". Click on the fuzzy pictures in the links to see them. They have been added to the page that comes up. There are also so service bulletins so the answer may be in them. https://www.wheelhorseforum.com/search/?q=36yr01&quick=1&type=downloads_file Garry Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,996 #3 Posted April 28, 2021 Ended up finding an illustrated parts list for the 95-36YR02 but for some reason there are 2 pages for 2 different decks I think. One shows blades with the 5/8" x 3/4" double-D center hole and the other with 3/4" round center hole. Stuck this file with the 95-36YR01 file so they are both together. Garry Share this post Link to post Share on other sites
pacer 3,179 #4 Posted April 28, 2021 Is your existing belt still intact, just worn badly? If so you can rely on the tried/true method of measuring it. Even if it broke but left fairly decent ends a good belt man can get a measurement... 2 Share this post Link to post Share on other sites
Jack marcham 51 #5 Posted May 1, 2021 On 4/28/2021 at 9:59 PM, pacer said: Is your existing belt still intact, just worn badly? If so you can rely on the tried/true method of measuring it. Even if it broke but left fairly decent ends a good belt man can get a measurement... its missing i didn't get it when i baught it Share this post Link to post Share on other sites
