Bill D 2,678 #1 Posted April 28, 2021 I need a wiring schematic for a 416H , Model 73421, S/N 4900466. It has no power to the ignition switch and and will not start with the key. There is power to the light panel regardless of key position as the push to test switch for the idiot light panel works. If you jump the battery positive to the coil positive it will start and run with the key. Thanks for the help. Bill Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,067 #2 Posted April 28, 2021 If you want to just view the wiring click on the picture in the link. You can download the file there also. Share this post Link to post Share on other sites
johnnymag3 2,643 #3 Posted April 28, 2021 (edited) Bill, the wire to the Indicator Light Panel is 12v live all of the time. It is one of the wires on the keyswitch and is with another wire to provide 12v when ignition is on. This is a 25 Amp fused line from the battery.... If there is 12v there, you may have a broken wire or a poorly connected wire in your case. There should always be live 12v to the keyswitch….trace your wire back to the Battery and I think you may find your problem. Check the Main fuse also if you didn't already...and check the fuse holder with a test light to be sure both sides of the fuse have power...Sometimes the fuse holders go bad.... Good Luck.... john Edited April 28, 2021 by johnnymag3 Share this post Link to post Share on other sites
