Butch 194 #1 Posted April 25, 2021 I put an electric fuel pump in my C-85 today. The ground is nothing. But where is the best place to attach the positive wire. Should I tie into the ignition switch or use something easier? Thanks. Butch S. Jersey 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,068 #2 Posted April 25, 2021 Should be powered by the yellow ignition wire going to the coil (+) Garrry 1 Share this post Link to post Share on other sites
squonk 45,811 #4 Posted April 25, 2021 (edited) I attach mine right at the coil +. I go overboard and power a relay from the coil + and then feed 12V directly from the battery to the other side of the relay to the pump. Edited April 25, 2021 by squonk Share this post Link to post Share on other sites
oldlineman 1,658 #5 Posted April 25, 2021 I picked the feed from my light circuit, I don't use the lights so just unplug them. You have to have the light switch on of course. Bob Share this post Link to post Share on other sites
Gregor 4,847 #6 Posted April 25, 2021 I must be the only one, but I have trouble with too much gas being delivered to a style 16 carb. I am using a good fuel pump. I started using the remote pulse operated fuel pumps. Hope they work. Share this post Link to post Share on other sites
Butch 194 #7 Posted April 25, 2021 Well I hooked up both wires to the coil. After playing with the choke she fired right up. Thanks guys! Butch S. Jersey 1 Share this post Link to post Share on other sites
