wikket 0 #1 Posted June 5, 2009 Hello, Hopefully somebody can help. I was wondering if a 12hp K series Kohler oil pan will fit on the 16hp Kohler. I have a K341, I guess it is from a Bolens or a JD, it have that little rectangular sump at the middle of the pan. I am planning to put the K341 on my C-85. Share this post Link to post Share on other sites
WH854 45 #2 Posted June 5, 2009 Maybe this can help you! Put this in for the model # (01-10K801)scrol down click on single cylinder engines. https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro check out part # 11 this part bolts to the bottom of oil pan.The oil pan fits in the rectanguler hole if you notice. Chas. Share this post Link to post Share on other sites
WH854 45 #3 Posted June 5, 2009 BTW you can get a lot of information from Brian Miller about Kohler engines here. http://gardentractorpullingtips.com/index.htm Try it out you will learn a good bit. Chas :drool: Share this post Link to post Share on other sites
wikket 0 #4 Posted June 5, 2009 Thanks for the help WH854, This is more information than I needed. :omg: Share this post Link to post Share on other sites
WH854 45 #5 Posted June 5, 2009 You can never have to much infotmation I hope it helps with your problem Chas :drool: Share this post Link to post Share on other sites
wikket 0 #6 Posted June 5, 2009 The C-85 is already up and running with the 16Hp. The only problem is the oil drain location on the current oil pan. I was thinking about replacing the oil pan to something that a WH uses. Easier for oil change. Share this post Link to post Share on other sites
WH854 45 #7 Posted June 5, 2009 I own a C-105 WH the oil pan has a drain out the bottom of the oil pan. The engine is bolted to what Wheel Horse calls an engine cradle. The oil pan fits in that hole in the engine cradle. I think that oil pan is an OEM part just for use on the engine cradles. Those cradles are like motor mounts in a car, They keep the engine from shaking itself a part if you know what I mean.I don,t think its a good idea to bolt big block Kohler right to the frame. Thats my 02cents. Chas Share this post Link to post Share on other sites
Don1977 605 #8 Posted June 6, 2009 I have an owners manual for model K241S, K301S, K321S they all use oil pan Part No.237763. It doesn't have K341 listed. They all list 1 quart oil capacity, and the stroke on the 12 and 14 is listed as 3 1/4" there may not be enough room for the stroke on a 16 HP. Share this post Link to post Share on other sites
